oil can as overflow?
Old Oct 12, 2010 | 12:53 AM
kennymo's Avatar
does anyone know if it would be possible to use the nrg oil catch can that i have as a coolant overflow tank instead?
Old Oct 12, 2010 | 01:24 AM
CandlestickPark's Avatar
ill Sedan
Nope don't believe that would work Kenny. If you are looking to do polished tanks you should consider Sean's overflow tank (square shape) or Weapon R (cylindrical shape). Sean's is way higher quality, but if you don't want square tanks then the Weapon R is the way to go. I believe it needs to be modified to work properly on our car. Technosquare has modified a few for the Gs in SoCal that run them.
Old Oct 12, 2010 | 01:46 AM
kennymo's Avatar
this is how i was thinking of doing it...
i flipped what is normally the top and put it on the bottom and vise versa. that way the to nipples are on the same end as the drain plug. im thinking if i hook up the hose that goes to the rad to the drain on the catch can. and plug the 2 nipples then it will work. maybe im still wrong though? i know that will look kinda strange. but i plan on tucking it down out of the way so it wont be very noticable at all.
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
