loss in power!! plz help
Old Oct 14, 2010 | 06:50 PM
rob g35's Avatar
Unhappy loss in power!! plz help
guys i have 5at 2003 tunedg35 BC cams and valve springs, spacer, CAI, hks and headers..suddenly i had a great loss in power its like 2.5l now..i put on scan it showed an error in the cam shaft sensor i changed it but nothin changed so what would be the reason??
Old Oct 14, 2010 | 07:11 PM
gtoor1990's Avatar
For my previous 5at i had problems with the headers... i took it to the mechanic and he said they wereint installed properly and the gaskets were leaking or whatever... Could be that or possibly just try a ecu flash...
Other then that lets see what other people have to say
Old Oct 14, 2010 | 07:16 PM
rob g35's Avatar
i dont think so from headers i installed them from like 5 monthes and it was normal and i was satisfied with great performance why now?
Old Oct 14, 2010 | 07:19 PM
gtoor1990's Avatar
It was the same thing for me... O yes I forgot to add he also said something about one of the spark plugs misfiring so he changed one of the spark plugs as well... But I feel you for me the car was really sluggish that's why I got it checked out.
Old Oct 17, 2010 | 12:48 AM
GHOS7's Avatar
rob g35, If you have more information it would be very helpful in routing you to the right direction. Like did you buy a new part before this happened?
Btw... seeing how the scan tool told you that the sensor was bad, and even after you replaced it, the problem still isn't resolved, I would check the harness for bad wires/terminals.
GL
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
vamarris
Sep 26, 2015 12:56 PM
zcherub
Sep 10, 2015 12:03 PM
