Timing Belt and Brake
Old Oct 23, 2010 | 04:37 PM
congvu's Avatar
Smile Timing Belt and Brake
Hello Guy! I just bought G35 one month ago. I already changed the brake pads but sometime it still makes noisy. I don't know why. Do you have any ideas about it?
by the way, How many miles to change the timing chain or belt and oil in gearbox? My G has reached 65k miles so far.
Sr i just bought my G, so i don't have any experience about it. Please help me.
Old Oct 24, 2010 | 10:44 PM
HangUp n' Drive's Avatar
Did you re-surface/turn your rotors?
No timing belt, has a chain, you do not change.
If you do not know when the gearbox oil was changed then it is time, the rear differential oil, and coolant (anti-freeze), same.
Old Oct 25, 2010 | 12:57 PM
gary c's Avatar
Our Infinitis should have all their fluids changed every 30K miles, check with Infiniti for service records....just don't take it there for service. Find an independent shop or Nissan since your cost will be considerably less. Who did the pad change for you and did they resurface your rotors? Did they use the lubricant on the pads when they installed them? Our Infinitis don't require changing the timing chain until you've surpassed 100K+ miles.
Gary
Old Oct 25, 2010 | 03:23 PM
jibberjabbers's Avatar
@ 65k I would check the plugs for oil, the compression rod bushing for cracks, (the entire suspension parts for that matter), replace all fluid, (brake, trans, clutch, radiator, rear differential etc)... Check all belts for wear and tear and so on.
Just look at the service manual and see the check list.
Old Oct 26, 2010 | 02:55 AM
congvu's Avatar
Thanks for your advise guys. I'll try to work on it.
Old Oct 26, 2010 | 02:59 AM
herrschaft's Avatar
If you have new brake pads and they're squealing, you probably just need to grease the back of the pads.
jsimonk
Dec 22, 2023 03:49 PM
wuppiedog
Aug 7, 2015 11:16 AM
sahizzle110
Jul 29, 2015 11:36 AM
itschuckster
Jul 25, 2015 08:07 AM
Lsantana757
Jul 20, 2015 09:08 AM
