Thermostat Housing Bolt Hole Stripped
Old Nov 22, 2010 | 04:32 PM
agent marlon's Avatar
Installed a new thermostat on the g35. When I went to put everything back together, I noticed that the thermostat housing bolt hole at the bottom is "slightly" stripped. I say "slightly" because it can be snugged up to where it cannot be moved by hand but not tight enough to keep a tiny bit of coolant from weeping out around the gasket at that end of the housing when the engine is running. The other 2 bolts is fine BTW and can be tightened down nicely. Is using a heli-coil or perma-coil to renew the bolt hole the best solution or is there some other way of fixing this problem?
thanks for the help
Old Nov 22, 2010 | 04:43 PM
Jeff92se's Avatar
Red Card Crew
You got it. heli-coil is probably the most 'correct' option.
magnetism80
Feb 1, 2019 10:00 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
JKL1031
Lights
Sep 9, 2015 01:27 AM
