Thermostat Change
Old Nov 23, 2010 | 02:39 PM
2slickg35's Avatar
Thermostat Change
I'm just wondering if anyone here changed out their thermostat by themselves. When I was considering to change it myself, it looks kind of hard because of the tight space to access the thermostat.
Old Nov 23, 2010 | 03:38 PM
bigc's Avatar
Wings Nation
its not hard. just drain some coolant from the radiator (or don't), unclamp the two hoses going into the t-stat, pull them off (put a towel underneath to catch the coolant that will leak out), remove the 3 bolts, swap the t-stat & gasket, then put everything back together. if you're still running the OEM intake, you'll probably have to pop loose the air duct too.
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
mikemf8
Sep 3, 2015 08:01 PM
TheBay
Sep 3, 2015 03:27 PM
NohoG35revup
Aug 22, 2015 12:13 PM
