2004 g35 coupe coolant change tutorial?
Old Dec 2, 2010 | 04:47 AM
djbookz's Avatar
Hi, anybody got easy steps to change the coolant. or have a tutoria?l thanks!
Old Dec 2, 2010 | 04:48 AM
djbookz's Avatar
2004 g35 coupe coolant change?
hi, anybody got easy steps to change the coolant for the g35? i saw a video tutorial on infinitihelp.com , but i don't understand the air release valve and when to open and close it? any help would be great!
Old Dec 2, 2010 | 11:05 AM
brandon1978's Avatar
https://g35driver.com/forums/faq-diy...e-manuals.html
There is a "Flushing Cooling System" section in co.pdf. It can be difficult to get all of the air out of the system. Pour in the coolant at a rate of <= 2qt per minute. If you have an aftermarket coolant control valve, make sure it is open. When the coolant is full, you can squeeze the upper coolant hose to get some air out of it. Don't overtighten either of the plugs, they are plastic and could break. Changing the o-rings on the plugs isn't usually needed and either is removing the plugs on the engine block.
vmcarbuyer
Oct 12, 2019 12:42 PM
brycealbr
Aug 11, 2015 11:47 AM
igking
Jul 19, 2015 01:12 AM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
