Rear Camber correction rod install tips?
Old Oct 28, 2004 | 09:47 AM
kenchan's Avatar
Anyone do the rear Kintex or Stillin camber correction rod for the G35/350Z's in the past? Do I need to watch out for anything when I do the swap?
Also, I want to play around with different camber settings
before I take it into the alignment shop for its final alignment.
How is toe affected by changing the rear camber? Say my car is at -3 camber and toe-in .15 each side. If I changed
to -1 camber, would it toe-in or toe-out?
2004 G35C 6MT Brilliant Silver
Old Oct 28, 2004 | 12:31 PM
kenchan's Avatar
Re: Rear Camber correction rod install tips?
anybody? ??
Old Oct 28, 2004 | 01:04 PM
neffster's Avatar
I'm getting an alignment done at 2pm today. I'll ask (if I can remember) while I'm there.
John Kerry promises a $1000 middle class tax cut AFTER the Bush tax cut expires.
The Bush tax cut is ~$3500 per middle class family.
JOHN KERRY = MIDDLE CLASS TAX INCREASE!
Old Oct 28, 2004 | 01:54 PM
kenchan's Avatar
I stopped my UlimateZ moments ago to pickup the Stillen
camber correction rods. The guy there told me that
more camber = more toe out.
So for example if I currently have -3 camber on the rear
and played with it so it will be -1.5, then I will result with
more toe-in.
The stillin rods come with instructions on how to install,
so will give it a shot tonight.
Old Oct 29, 2004 | 03:56 PM
kenchan's Avatar
Install went pretty smooth. Nothing really hard. It was
easier to access the locknuts on the hub carrier side
taking the wheels off. That's about the only difference I did
vs the Stillen instructions.
Got the car aligned, dialed in at -1.4neg camber with
.15 /.14 toe L / R. Car runs and looks great.
no need for the toe alignment rod for the Eibach lowering
springs.
youngdip631
V36 Brakes, Suspension, Wheels & Tires
14
Jul 29, 2015 11:28 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
Soumilg
Jul 18, 2015 12:33 PM
