consuming oil
Old Jan 14, 2011 | 10:31 PM
omfgedwin's Avatar
consuming oil
2004 G35 coupe 5AT 95k consuming oil.. its either a piston ring, head gasket, or valve seals.. Don't know weather it should be repaired or i should look for a used motor.. Doesn't feel right just throwing the motor out.. lol What you guys think.. Will any basic mechanic be able to repair it? Average cost of used motor or repair? im in ny btw..
Old Jan 14, 2011 | 10:36 PM
thescreensavers's Avatar
Mr.202?
How much oil is it consuming. Have you tried thicker oil?
Old Jan 14, 2011 | 10:39 PM
the_sedan's Avatar
normally rings. you can re-ring the motor. master gasket kit is like $400 from the dealer plus rings and bearings and labor. you might come out equal as if you went with a used motor and labor to install, only you will pretty much have a new motor.
Old Jan 15, 2011 | 12:14 AM
omfgedwin's Avatar
dropped a lucas on it today.. see how it goes..
Old Jan 15, 2011 | 12:15 AM
Mr.202?
^ dropped a what? lol
Old Jan 15, 2011 | 01:03 AM
omfgedwin's Avatar
its like a heavy oil.. they sell it in autoone, its a white bottle...
Old Jan 15, 2011 | 01:24 AM
Mr.202?
should try thicker oil first. Forget additives. Oil is already formulated properly by adding additives your changing how it was engineered to work
Old Jan 15, 2011 | 02:35 AM
tyau's Avatar
Lucas is just a very thick petroleum oil without additives. It's okay for oil burning, but overkill to use just for "consuming oil". Lucas could resurrect dead motor from extremely worn piston rings.
Old Jan 15, 2011 | 12:10 PM
teahead's Avatar
symptoms?
blue smoke? >2qts between oil changes?
Old Feb 23, 2011 | 10:31 AM
G35 Owner's Avatar
Any updates to your situation? I think I'm headed down the same path. Did you get any quotes? What action did you take?
Old Feb 27, 2011 | 06:51 PM
JZ39's Avatar
I'm right there with you guys. 105k and oil burning seems to be getting worse. The rest of the car is mint, so it doesn't make sense to get rid of it.
The odd thing is that my car doesn't ever smoke, but I am using probably 1 qt every 1000 miles. I know I need new valve covers, but I can't imagine this could be the cause of this kind of oil use.
What are our options?
Old Feb 27, 2011 | 10:01 PM
Tollboothwilley's Avatar
rebuild or replace - or you can just keep adding oil until it gets to the ridiculous point.
Old Feb 27, 2011 | 10:17 PM
teahead's Avatar
Use super thick 30 or 40 weight oil.
Old Feb 27, 2011 | 10:46 PM
the_sedan's Avatar
i dont think these motors will like heavy oil.......but i wouldnt know. never done or heard of anyone tryin it. either way, rebuild or replace. only options.
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
