Heating problem!
Old Nov 2, 2004 | 05:28 PM
pathfinder36's Avatar
Heating problem!
For some reason, my heater stoped working properly today. Usually, I don't need to turn it above 80 to get it SCREAMING hot inside my 04 coupe, but today, 80 just blew cool air. 90 was pretty warm, but what gives????
I recently put a new stereo in my car, but I kept the factory head unit. Is it possible something got loose behind the face plate or maybe blew a fuse?
Old Nov 2, 2004 | 08:44 PM
rcdash's Avatar
Re: Heating problem!
sounds like the ac controller wiring may not be reconnected appropriately? was it ever disconnected when the new stereo was put in?
Old Nov 2, 2004 | 11:02 PM
wizawuza's Avatar
odd problem... where's the new headunit if you kept the orig?
try testing ALL of the buttons when you get a chance.. ie, try temp up/down, ac, rear defrost, etc. Doesn't hurt to see if something isn't communicating correctly.
2004 TB/W 6mtC. Sunroof only.
Bel Vector 985
Grounding Kit
Splash Guards
Custom Carputer
Custom FG Sub
Infinity KapPerf6.1, Ref 6002si, 5760 6-ch AMP.
30% Huper
Old Nov 3, 2004 | 09:09 AM
cato's Avatar
SouthernComfort Moderator
Funny thing about the G35 is that he heater/AC is combined
with the head unit. I bet your install has somehow messed
this up.
03 5AT Sedan, sunroof, splashguards, HKS muffler,
14 wire Grounding kit, Z Duct, Stillen HF/AB
Underbody rear diffusers, Drilled alum pedals,
Stillen sway bars S/H. Sport Tuned Suspension
Old Nov 3, 2004 | 03:15 PM
Got it figured out. I went into the diagonstics screen on the A/C. I reset the whole system and recalibrated the internal thermostat. Works like a champ.
Old Nov 3, 2004 | 03:48 PM
wizawuza's Avatar
I don't have this problem, but it'd be nice to know just in case.
How do you do diagnostics with the A/C unit?
Thanks
Bel Vector 985
Grounding Kit
Splash Guards
Custom Carputer
Custom FG Sub
30% Huper
Old Nov 4, 2004 | 01:59 PM
Turn your key on
Turn the ac off
Turn car off
Turn car back on and QUICKLY hold down the AC off button
You'll see the diagnostics mode come on. You'll have to kinda explore this, but to simply adjust the temp output +\- 6deg:
Hit the temp up button till you see 51 or 52 (it's the last option).
Hit the front window defogger button
Hit the fan up button
Then adjust the temp output +\-
There's lots of things you can do in this mode, but I'd have to spend some trial and error time unless someone knows for sure what everything does. I managed to reset the system settings, but that was merely an accident.
Old Nov 4, 2004 | 08:54 PM
Gordgee's Avatar
Administrator
That's pretty cool! I'm going to have to try it sometime.
Maybe you can find the secret sequence to completely disable the VDC, from your "source".[img]/w3timages/icons/wink.gif[/img]
I know that M-B has one.
<font color=blue>[i]GroundingGear™ Equipped </font color=blue>
Old Nov 5, 2004 | 08:24 AM
gersteinp's Avatar
The specific way to "trim" the interior temp setting is as follows:
Turn key to on (or start car)
Within 5 seconds hold down OFF button until screen changes
Keep tapping TEMP up until "51" shows.
Touch DEFROST then FAN up.
"61" shows briefly, then "0" or whatever trim setting is already in there.
Now, by hitting TEMP up or down you can trim the interior temp by 6 degrees plus or minus. Hit AUTO/ECON to exit.
For example, if you want the interior temp to be 3 degrees cooler for a given setting, tap TEMP down until "-3" shows.
There are other diagnostics that can be performed using this method--but this is the only trim setting (otherwise known as recalibration).
Old Nov 5, 2004 | 10:35 AM
cato's Avatar
This is good information. Maybe it should go in the DIY section?
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
mattdg35
Sep 14, 2015 11:28 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
Jnm07
Sep 5, 2015 01:16 AM
