x pipe test pipe help!!!!
Old Jan 31, 2011 | 01:51 PM
g23nismooo's Avatar
my car is 03 sedan AT. i have no resonater or muffler box. so it is basically straight pipe from the cats. it has a nastttyyy rattle noise when i go over 3000 rpm. i want to lower the voice a little bit nd get rid of the nastyness. i know that test pipes will only make it lowder. my question is, will 350z or g35 coupe x pipe fit on the sedan? Will i need to do any modifications to get them to fit? Also what difference will I see if i install the x pipe? thank you for your help
Old Jan 31, 2011 | 04:48 PM
Jeff92se's Avatar
Red Card Crew
Y pipe?? No 350z or G35 came with an X pipe.
Old Jan 31, 2011 | 04:52 PM
nissanunlimited's Avatar
the g35 Coupe will.. I'm not sure if the 350z one will fit tho.. i dont think so..
i also had a question similar to yours.. i wanted to know if the 350z HR mid pipe would bolt on to our g35 Sedan's??
Old Jan 31, 2011 | 04:54 PM
Jeff92se's Avatar
Red Card Crew
Yes
Old Jan 31, 2011 | 05:12 PM
The Y pipe is the same on all models Gs and Zs g23nismo.. No difference until 07-08 350z, which in this case still fits our sedan's and coupes.. The flow is slightly better in the 07-08 350z MODELS, and of course the 07 g35 sedan HR engines..
magnetism80
Jan 27, 2016 12:57 PM
Atwork
Intake & Exhaust
Sep 20, 2015 03:36 AM
Albanian122
Sep 12, 2015 04:02 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
