Oil in plenum
Old Feb 15, 2011 | 04:30 PM
omfgedwin's Avatar
Oil in plenum
Ok so my car is currently smoking white oil at start up.. Changed the spark plugs which were super wasted.. car has 94k miles. Just installed my motordyne spacer, and in the process i saw some oil in the plenum. Also, when i changed the spark plugs, to 2 rear ones had oil in them.. not much though.. What you guys think?
Old Feb 15, 2011 | 04:34 PM
LordFappington's Avatar
Its normal, its not normal if there is a standing pool of it though.
Old Feb 15, 2011 | 11:15 PM
sillyoldtayo's Avatar
oil on the plugs is not a good sign. I would get that checked out. oil in the plenum is normal according to Motordyne haha. My car had a little bit of oil in the plenum as well. Seems like a lot of cars have it.
Old Feb 18, 2011 | 08:43 PM
gary c's Avatar
Installing a "Catch Can" will eliminate any oil in your plenum which I've always considered a good idea....
Gary
Old Feb 20, 2011 | 12:21 PM
Cox_G35's Avatar
did it smoke like this. my car starting smoking after i installed a "catch can"
Old Feb 21, 2011 | 11:40 PM
omfgedwin's Avatar
naa that seems like antifree smoke.. my smoke smells like burnt oil and bluish
Old Mar 5, 2011 | 02:37 PM
cthrulies's Avatar
I'm using a catch can from custom corvette accessories. It mounts perfectly on the passenger side of the engine. Remove the bolt that secures the power steering reservoir bracket to the chasis, align the PVC Catch Can braket hole, reinsert the bolt, tighten, secure hoses, DONE. You will suprised at the amount of oil this thing "catches".
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
mbe32
Nov 13, 2015 11:09 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
wow600rr
Sep 28, 2015 11:50 AM
