people that have done wiretucks themself
Old Apr 5, 2011 | 03:06 AM
kennymo's Avatar
mods if this is in the wrong location please move. and sorry ahead of time...
i was just looking at the DIY that heist made up of how to do the main harness. and i noticed that he removed the plenums to do the wiretuck. but as i read farther into it, he pretty much took the whole front loom and moved it to the back of the motor. so my question is why does the plunum need to be removed? why cant i just take the intake tube off and then undo the loom and start moving wires up and over the plunum to be behind it and then remake the loom in the back?
Old Apr 5, 2011 | 03:10 AM
That G Gray's Avatar
Because it makes for a much less cluttered area. Also, by removing plenums you can access wires that need to be rerouted and this makes it that much easier to do so. Try it with it all on and see how far you get.
Old Apr 5, 2011 | 03:12 AM
kennymo's Avatar
i dont want to try it with it all on if its not going to work. thats the point of this thread. to understand WHY people take it off
Old Apr 5, 2011 | 03:14 AM
And I told you why :-)
You cannot tuck most wires if you do not have plenums off.
Old Apr 5, 2011 | 03:17 AM
kennymo's Avatar
ok thank you.
just curious, have you personally done it? and if so can you list which wires you know of that wont be able to be tucked?
Old Apr 5, 2011 | 03:20 AM
Yes I have. Too many things to list. Beat advice is to take your time and label EVERYTHING you disconnect.
Old Apr 5, 2011 | 03:29 AM
SxExCx's Avatar
I dont see how it can be done right without removing the upper and lower plenum.
SxExCx's Avatar
...and yes, I have done my fair share of tucks!
Old Apr 5, 2011 | 03:31 AM
It simply can't. You must remove them both :-)
Old Apr 5, 2011 | 12:54 PM
the_sedan's Avatar
you have to pull them off. you have to route and make the harness in a neat manner for the coils and the VTC solenoids. and for the solenoids/sensors on the timing cover if you're a revup.
Old Apr 5, 2011 | 12:56 PM
CandlestickPark's Avatar
ill Sedan
Kenny stop being lazy and just remove the plenums.
Old Apr 5, 2011 | 12:59 PM
SxExCx's Avatar
^lol
Old Apr 5, 2011 | 01:16 PM
nico oner's Avatar
Do any of the wires need to be extended (cut/soldered) ?
Old Apr 5, 2011 | 01:17 PM
ill Sedan
^No, you can do the tuck without extending any wires.
SxExCx's Avatar
^no
