car keeps backfiring! need help :(
Old Apr 7, 2011 | 06:04 PM
sirgeathan's Avatar
hey, i have a 04 g35 coupe running at 150,000km. backedfired 3times.
1st time it backfired, coils burnt out and made a hole in the driverside cat. Replaced the coils and sparkplugs and drove. a week later, backfired on me again. towed it back and chk it up with a mechanic and he said it was the ECM that was giving problems.
Replaced the ecm, reprogrammed it, replaced the coils since it was under warrenty and replaced the cat with a used one which was in really good condition. parked the car for winter storage.
Yesturday i finally pulled the car out, did the emmsissions, and passed. while driving back home, car backfired on me again. now its sittin at the garage.
if anyone came across of had this issue, please help me out =) thanx!
Old Apr 7, 2011 | 11:52 PM
the_sedan's Avatar
sounds timing related.....yet odd how its random and not a constant issue. does it run good and strong otherwise? how is the timing when consult is hooked up...idle/accelerating?
Old Apr 8, 2011 | 01:32 AM
sirgeathan's Avatar
when the car starts backfire, cant drive the car for long. it would make like a gun shot noise n then i would have to tow the car to the garage. every time it does that, it would make a hole in the driverside cat and burn the coils. my mechanic said it was the ecm that wasnt giving power or single to the sparkplugs and i replaced the ecm. now that i changed the coils again the car wont start. pretty much somthing to do with the ecm or wiring??
Old Apr 8, 2011 | 02:12 AM
Eric@TCGMiami's Avatar
Take it to the dealer
Old Apr 8, 2011 | 11:46 AM
the_sedan's Avatar
so you've got a new ecm and coils? did you re-register and re-learn everything with the new ecm?
Old Apr 9, 2011 | 10:46 AM
sirgeathan's Avatar
the ecm was programmed and tested the 1st time. just found out that the ecm that i switched with was defective. only had 6month warranty n its been 8month. is there any way that you can rebuild the ecm??? im from canada, ontario
chinee
Jun 10, 2024 07:48 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
marsman328
Northern California
Aug 11, 2015 07:29 PM
newg37
Jul 26, 2015 09:32 AM
Karnicle
Jul 23, 2015 05:08 AM
