Engine ticking noise
Old Apr 28, 2011 | 11:00 PM
tuffenuff's Avatar
Hiya,
I have searched all engine ticking noise threads but haven't found any exact
same noise sample with my G.
03 G coupe 6MT. 80k miles.
Here are things have been done to fix this noise.(None of them worked. lol)
1. Drained engine oil and filled up with the thickest oil which Infiniti dealer recommended.(sorry I don't remember the exact name of it)
2. Had timing chain tensioner replaced at infiniti dealer.
3. Had valve/lifter diagnosed at dealer while the timing chain/tensioner was being replaced. They said it's all normal.
I've got a video here. (I don't hear any ticking noise from cabin but it's pretty noticeable from outside. The noise is a bit more louder in the video.)
Anyone has the similar noise? What could it be?
Thanks in advance.
Old May 1, 2011 | 03:26 PM
xxxxxxxxxx's Avatar
does it do it when you start the car only or always?
Old May 2, 2011 | 06:50 PM
papercuts's Avatar
https://g35driver.com/forums/engine-...nt-needed.html
i myself have searched that thru google and found this. hope this helps. also myne ticks as well. only noticble outside the car.
Old May 3, 2011 | 12:55 PM
tuffenuff's Avatar
Yes, it always does.
Old May 3, 2011 | 12:56 PM
tuffenuff's Avatar
Oh, many thanks for the info. I will look into it. Thanks again!!
Old May 3, 2011 | 11:54 PM
Sylvan lake V35's Avatar
it is tough to tell but it could even be an exhaust leak
Old Jun 3, 2011 | 08:56 PM
TightGTurn's Avatar
Those are your lifters. Also, I would HIGHLY doubt that the dealer did a valve/diagnostics since the ONLY way to determine if the gap is within spec is to measure each lifter on the cams high stroke. All 24 of them and its a PITA!
I've seen this happen to motors with either low oil or bad oil. If the engine is revved with low oil, the lifters warp or dimple on the down stroke of the cam. This will increase the gap clearance and cause the sound you just heard, causing the lifter to move around in the socket.
Usually you have to take the engine out because getting to cylinder 5 and 6 is almost impossible to measure without the engine out. Crappy thing is a lifter replacement is a $32-$35 part.
rezendvous420
May 31, 2020 01:26 PM
Sepsis
Feb 12, 2020 02:05 PM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
joedaddy1
Jul 28, 2015 02:58 PM
rping
Jul 26, 2015 09:53 PM
