ac belt tensioner pulley bolt size
Old May 14, 2011 | 01:42 AM
kennymo's Avatar
does anyone know what the thread pattern/pitch is for the bolt that holds the ac belt tensioner pulley on? i know the tool size that is needed is a 9/16, but i need to replace it and i need to know what bolt to get.
Old May 14, 2011 | 04:00 AM
RRYDE's Avatar
First of all you need to use the proper tools. SAE wrenches should not be used on your car. Every nut & bolt on our cars are metric, so use only Metric sized tools.
Are you refering to the nut that is the center of the pulley ? -
It is 10mm X 1.25 - 14mm wrench
The bolts that secure the pulley bracket to engine - 8mm X 1.00 - 12mm wrench
Old May 14, 2011 | 12:38 PM
kennymo's Avatar
only reason i said it was a 9/16 is because thats what the diy says to use.
Old Apr 14, 2013 | 10:41 PM
wompem's Avatar
Hate to drg this thread up from the dead, but is the the other belt tensioner nut the same? I was trying to tloosen that one and it started to round. Looks like ill need to use a round nut socket and will need a replacement.
Old Apr 25, 2013 | 09:57 AM
eZg's Avatar
eZg
Not sure but my crank side tensioner pulley came off yesterday and I KNOW I tightened that B!tch down to specs.....guess loctite next time.
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
