Engine ticking/clicking and need your help. youtube video included.
just picked up a 03 G35 sedan from a small lot. 59000 mile, clean and pretty much regular daily driving wear. The engine has a clicking or ticking knock noise coming from the drivers side of the engine or so it seems. One of my friends said it is possibly lifters, others said bent valve. The mechanic at the lot said all it needed was a tune up, oil and spark plug change and it would go away....It hasnt after 700 miles. the car still has their warranty so im getting it fixed through them. Here is a Youtube video of the noise.....thanks for your help!!!!
This is the actual car and noise, not some random video. thanks for your help.
FYI, Read the TSB's on this one. The troubleshooting test is if the engine
is low on oil add oil. If the engine makes noise it needs to be replaced or repaired.
The lifters are hydraulic and when they are starved for oil they will not pump-up. What you are hearing is lifter slap. When the engine is cold at start-up the noise is louder then after the engine warms-up. If the noise goes away "Great" that is normal operations of a hydraulic lifter.There is a few things that can be done to try to free-up a stuck lifter.
Now if it doesn't go away you need to get into the motor or pay someone else.
Warranty would be real nice about now !.
Hey guys...yep, one of my lifters is bad so im getting all of them in new...24 lifters=$750 from infinity dealer...luckily the lot warranty is still in effect...idk what is the labor tag for this...thanks for your help
pigpen infiniti
Aug 16, 2015 09:07 PM
yassy
Aug 9, 2015 07:31 PM
