Throttle Response delay?? (vid included)
Old Jul 14, 2011 | 10:14 PM
mikes3kgt's Avatar
I have a 04 6mt coupe mods are...
Polished Z Tube.
ART Pipes.
K&N drop in.
5/16 MD Spacer.
The car has a delayed throttle response and almost feels like its bouncing off the rev limiter. 2 other members checked the car out and said the same exact thing. They drove it and reved it. I raced a automatic G today to see the difference and he had a car and half on me from a 20 roll 30... and 40. Even from a dig. His car gets instant power and mine doesnt. When you floor it the car lags to get power from 3k RPM - 5500RPM. This has been happening since before the mods too. The car did have a clogged CAT before and i replaced it then got ART pipes.
Ive cleaned the MAF and replaced Spark Plugs. I use OEM oil and car has 96k Miles.
Here is the Video.
Any help would be great!!
-Mike
Old Jul 14, 2011 | 10:42 PM
ldg870's Avatar
Did you reset the ecu?
Old Jul 14, 2011 | 10:45 PM
mikes3kgt's Avatar
Yes reset ecu and everything else.
Old Jul 14, 2011 | 11:37 PM
almost3flips's Avatar
I have an idea mike...try seafoaming it
Old Jul 14, 2011 | 11:48 PM
Yeah try cleaning he throttle body or maf whichever you didn't and seafoam it dude...it looks like that may be your fix
Old Jul 15, 2011 | 03:14 PM
DaveB's Avatar
What other exhaust mods do you have? The car sounds awful, almost like it has a leak between the head and manifold. That can cause a loss of throttle response. Same goes for overly large exhaust piping or open exhaust on an NA motor.
There could be a problem with the electronic pedal assembly or the throttle body. You might want to consider disconnecting the negative terminal on the battery and unplugging and replugging in the connectors on the pedal assembly and throttle body. If that doesn't work, then you might want to take to Nissan/Infiniti. They'll plug in the Consult computer and it will give them all the sensor values and see what's lagging in the motor.
Is the CEL on?
Do not Seafoam it, that's not your problem.
Old Jul 15, 2011 | 03:17 PM
rcdash's Avatar
Car has normal oil level? Something does not sound right!!! You might want to pull the oil pan and make sure you haven't done some damage when you had the clogged cat (look for metal flakes).
Old Jul 15, 2011 | 03:41 PM
mikes3kgt's Avatar
Yeah oil level is all good.
Im pretty sure i didnt spin a bearing.. I know what thats like from when i used to own my 3000gt VR4. So im sure of the sound. And the sound of the car sounds normal.
Old Jul 15, 2011 | 03:53 PM
Yeah that sound is just from us disconnecting the y pipe from the cats to see if it was something in the latter part of the exaust that was causing restriction. Reason I say seafoam is after reading some other threads similar to this, some guy cleaned his tb and maf and injectors and it was back to normal.
Old Jul 15, 2011 | 03:57 PM
mikes3kgt's Avatar
On my way to Autozone now! So ill grab some TB cleaner and some seafoam. SES just came back on. So ill run the code.
Old Jul 16, 2011 | 01:10 PM
mikes3kgt's Avatar
So SES came on again. and it pulled the code p1283.
Is this code because of my ART pipes?
Or is it something else I should be looking at??
Old Jul 16, 2011 | 11:43 PM
Shakuya88's Avatar
I had this code when i did the TTs, with this, it is normal, for you being you have stock injectors and everything, and the exhaust sounds like that...You have a pre o2 exhaust leak. It's throwing so much fuel at it that it can't burn it all. Most likely the joint between the manifold and the ART pipes.
Old Jul 16, 2011 | 11:48 PM
Eric@TCGMiami's Avatar
Listen to DaveB....
Also you the exhaust coming out of your non existing muffler are explosions... your knocked sensor could potentially be catching these explosions and confusing them for knock thus the delayed throttle response.... I can assure you your torque is greatly degraded with this setup.
Old Jul 17, 2011 | 12:31 AM
G35SHAWN's Avatar
Take it to a muffler shop & have them check to see if there is any leak, bad gasket what have you. Also yes, clean your maf sensor as well. Also it's not a bad idea to a test engine compression.
Old Jul 17, 2011 | 03:33 AM
We had the exhaust unbolted when we shot the video lol but the delayed throttle was prevalent before that
Hasanbaloch
Feb 29, 2024 08:45 PM
Freeman186
Sep 6, 2023 10:07 AM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
