oil
Old Apr 23, 2003 | 03:33 PM
dspisak's Avatar
Re: oil
For which model of Nissan/Infiniti are you referring? Page 10-5 of the manual for my 2003.5 Sedan as well as the on-line version have no mention of synthetic oils.
FWIW, a review of the MSDSs of several popular "synthetics" indicates that they contain significant amounts of mineral base stocks.
<font color=blue>Dan</font color=blue>
Old Apr 23, 2003 | 03:35 PM
ryoken's Avatar
Re: oil
You wouldn't, by any chance, be referring to Castrol Syntec, would you? [img]/w3timages/icons/wink.gif[/img]
Old Apr 23, 2003 | 04:32 PM
dspisak's Avatar
Re: oil
Righto. That's one of them. To wit:
64741884 - SOLVENT-REFINED HEAVY PARAFFINIC
68037014 - 1-DECENE HOMOPOLYMER, HYDROGENATED
68649127 - 1-Decene, tetramer, mixed with 1-decene trimer, hydrogenated
92062094 - Hydrotreated Petroleum Slack Wax
The BMW version is:
64742547 - HYDROTREATED HEAVY PARAFFINIC
64742650 - SOLVENT DEWAXED HEAVY PARAFFINIC
The 1-decene components are PAO. I think they are manufactured by ChevronPhillips. The numbers are the CAS registrations, very helpful when deciphering a "miracle oil".
Old Apr 23, 2003 | 05:28 PM
johnzg35's Avatar
Re: oil
I bought my car last July.
I just compared page 10-5 in the old (2003) and current (2003.5) manuals and just as some of you have said, the reference to synthetic oil is omitted in the current manual. Who'd thunk it.
Old Apr 24, 2003 | 01:27 AM
IQ9's Avatar
IQ9
Re: oil
I have ALWAYS run Redline in my race vehicles and Mobil 1 in my street cars but I know what the dealers do, so I am covering my ***. They will hang you out to dry if it becomes a: you or them issue. It may be a myth but I can say this I know I will have no issues in the factory's eye. At 15K she will get Mobil 1 but for now I'll let my oil tests speak for themselves.
03.5 Sedan/B. Silver/Prem/Winter/Aero/Tint/Rims
69 Chevelle Hard Top BB/4.11's/Posi
Old Apr 24, 2003 | 07:20 AM
VNT's Avatar
VNT
Re: oil
johnzg35:
Actually the case is not closed, as it looks like you read page 10-5 from the sedan owner's manual.
10-5 on the coupe says you can't use synthetic oil the coupe.
For the 350Z owner's manual, it says you can't use synthetic oil.
The reason why? No one seems to know yet.
Old Apr 24, 2003 | 11:51 AM
ryoken's Avatar
Re: oil
It doesn't say you can't use synthetic, it just recommends mineral-based oil. I have the manual from a 2003.5 sedan, which also doubles as the coupe manual (it has sections referring to the differences between the two).
Old Apr 24, 2003 | 01:26 PM
malx's Avatar
Re: oil
Oh man, so many mixed opinions, can we all compile a senseable decision on what oils to use? Personally I got my oil changed at 3000 miles. I put in Quaker State Synthetic. I heard the best combination for the G was mobile 1 synthetic and 1qt of valvoline organic. I could be wrong, but your transmission seals are alerady set. If you drive your car (for the first 600 miles) below 3500rpms and than for the remaining 400 miles above 3500rpms (when you're on the highway) your seals will set really tight. And your engine is fully broken in along with the tranny. Doing this, Performance wise, you can get an extra 10hp (this may be a myth, but I believe it just because I have raced about 4-5 G's with my G and mine is slightly faster. (could be the driving though)
Old Apr 24, 2003 | 07:56 PM
GeeMan's Avatar
Re: oil
So I call the Service Department at Beaverton Infiniti (Oregon) and ask about switching to synthetic on my first oil change. He says no problem but keep up the maintenance schedule because, although the oil doesn't break down, there are still impurities in there that should be addressed with new oil and filter.
Sounding more and more like it depends who you ask. Since no warranty issues here, I'm going with syn.
03.5 Sedan AT (Black-Willow-Premium-Sport-Aero)
Old Apr 24, 2003 | 08:13 PM
ryoken's Avatar
Re: oil
Well, a new filter at least. If you want to extend your oil drains, you should use oil analysis to determine how far your engine is capable of running between drains. Probably wouldn't hurt to consider adding a bypass filter, too.
Although, if you're just interested in moving to the 7500mi schedule instead of the 3750 schedule, it's probably fine.
Old Apr 24, 2003 | 11:06 PM
nhoj's Avatar
Re: oil
The newer manual does say "INFINITI recommends mineral based oils" but also says "Only those engine oils with the American Petroleum Institute (API) certification mark on the front of the container should be used."
Mobil 1, Castrol Syntec, Quaker State synthetic and others carry this certification and do not violate the warranty.
JE
<P ID="edit"><FONT class="small"><EM>Edited by nhoj on 04/24/03 08:45 PM.</EM></FONT></P>
Old Apr 24, 2003 | 11:26 PM
ryoken's Avatar
Re: oil
You forgot your closing quote. Does your manual specifically mention Mobil1, Castrol Syntec, and Quaker State? Or is your quote supposed to end at ..should be used. ???
Old Apr 24, 2003 | 11:47 PM
nhoj's Avatar
Re: oil
Sorry...fixed now. The manual does not mention any brand. I did look specifically at those 3 oils today and they were API certified.
JE
Old Apr 24, 2003 | 11:54 PM
ryoken's Avatar
Re: oil
Of course they're API certified. I'd say a manufacturer would be hard-pressed to say synthetic oil caused your problem, as long as you change it at the recommended intervals and don't go for extended oil drains until after the warranty is over.
Old Apr 26, 2003 | 07:16 PM
  #30
GeeMan's Avatar
Re: oil
Changed mine today to syn: Royal Purple, 5W30. Took about an hour just 'cause I was unfamiliar and looking around under there (have the thick sway bars by the way). Hardest part was remembering which screws I'd already tightened of the MANY that hold on the air diffuser panel. Sheesh!
Next time I'd estimate not much more than 30 minutes.
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
