Cleaned injectors @ 128k miles
Old Aug 24, 2011 | 04:33 PM
Andrei's Avatar
I thought stock injectors are suppose to be Injector Dynamics, not Bosch? I found a lot of dirt, inside the ports and on the injectors themselves.
Old Aug 27, 2011 | 09:17 PM
Sylvan lake V35's Avatar
Did you just clean the exterior cosmetics or take them and have them flow tested & cleaned at an injector shop?
Old Aug 28, 2011 | 06:04 PM
Andrei's Avatar
It's cheaper to buy used injectors with low miles. I cleaned them up and primed them with some industrial degreaser and put them on the rails, the kind of degreaser that takes your skin off. So far no changes. I also had a friend peek in the radiator neck to look for bubbles as I reved the car and he saw no bubbles. I'm still going to check for exhaust gas in the cooling system next week at a radiator shop, should not cost more than $20 vs. me paying $53 for UVIEW.
If all else fails after I try other injectors I'm going to have to go to Forged Performance. It doesn't seem to be a bad MAF, though I could ask someone to let me borrow theirs for a bit so see if it stops running lean.
Old Aug 28, 2011 | 06:23 PM
infinitig35's Avatar
Looks like pretty tough work.
Old Sep 11, 2011 | 12:16 AM
CBRworm's Avatar
20 Year Member
In the future, I would recommend cleaning the exterior surfaces before pulling the injectors out. I use brake kleen followed by compressed air to get everything spotless before removal. This will minimize the amount of sand getting into the engine. I would also cover the intake ports to keep 'stuff' from falling in. I use masking tape.
Ken167
Aug 7, 2015 11:12 AM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
johnjohn077
Brakes
Aug 4, 2015 01:37 AM
newbdriver01
Jul 15, 2015 06:10 PM
