After installation of Transgo, engine won't start
Old Sep 3, 2011 | 04:40 PM
V.Capital's Avatar
Hi guys,
Here is my problem.
I installed the Transgo kit last night, and finished up the work this morning by refilling the transmission fluid.
Now the car won't start at all, no cranking no nothing.
I can tell the gear indicator is not working, shows nothing but blank.
Now I assume the problems could be:
1. there is a sensor somewhere i failed to connect.
2. transmission fluid over filled. will this cause the sensor fail to act normally? I can still move the gear stick and the machine reacts accordingly. Only without showing the gear icons.
BTW, the brake feels realy hard when stepping on for starting the car or change gear.
Any idea? i am so desperate right now. didnt even sleep for almost 24 hours.
any help will be appreciated.
thans guys.
Old Sep 3, 2011 | 05:39 PM
superchargedg's Avatar
Overfilling is not the cause.When you turn the key on what happens?
Old Sep 3, 2011 | 05:42 PM
JaE35's Avatar
Moderator
G35 Sedan
Man wish i could help you...go in the transgo DIY thread and ask this
Old Sep 3, 2011 | 06:27 PM
V.Capital's Avatar
On e dashboard all lights off except sevice engine n at check when turns the key to START. N the engine kept quiet, without even a click. I'm trying to open the valve body again. See if I missed anything. Wasted 7L fresh fluid tho.
The thread seems haunt been updated recently. Anyway thx guys.
Old Sep 3, 2011 | 08:19 PM
V.Capital's Avatar
Figured out what the problem was. Here in this pic, there are 2 cables, one is white one is black. On my valve body, the black one was cut by a screw when installing.
is it replaceable? I assume it is but what's name of this cable? valve body cable?
Thx for reply.
Old Sep 4, 2011 | 04:22 PM
I dont know what that would be called but you should be able to repair it.Solder the 2 ends together with shrink wrap shoud do the trick.
Old Sep 4, 2011 | 04:46 PM
g35man04's Avatar
CLUB MODERATOR
Just f.y.i. if you cant fix it by soldering understand that Infiniti does not sale any parts independently for this item which means you would have to find a messed up tranny or buy a new VB *700.00+ .....
I would think soldering would fix with shrink wrap added but not sure how that works with solder and Transmission fluid.
Old Sep 5, 2011 | 03:12 AM
V.Capital's Avatar
Okay here is the news.
I double checked everything, made sure that the replacement, the part which got cut off by stupid me, was working properly(got a tester on hand, and the line works perfectly).
When i tried to start the car again, still nothing. Then i tried to reset the ECU and other ****, desperately.
Suddenly, I notice the CEL flashed 5 times. Googled online, and found the means of this code, " Main fuse box not working, your car won't start." YOUR CAR WON'T START!!!! Again I noticed I forgot to disconnect the battery before taking the valve body off until I put everything back THEN I disconnected it. Will this **** the fuse box up?
How to check the fuse box?
Thx for the replies guys.
Old Sep 5, 2011 | 04:35 AM
V.Capital's Avatar
problem solved. a burnt AT fuse.
Old Sep 5, 2011 | 04:36 AM
psycobusa's Avatar
Most likely the fact that you put the screw in and it cut into that wire, when you turned the key on, it blew a fuse or shorted something. Don't know what to tell you except check your fuses.
nevermind I see you fixed it before I entered the post.
Old Sep 5, 2011 | 04:50 AM
V.Capital's Avatar
yeah bro even if i didnt i still may find the answer by ur post. thx!
Old Apr 23, 2024 | 01:48 PM
Abyss87's Avatar
5 Year Member
Where and what number is the fuse?
Old Apr 24, 2024 | 03:21 AM
Scorpi0's Avatar
Not sure what year or model your car is. But this might help u out:
https://fuse-box.info/infiniti/infin...and-relays/amp
chinee
Jun 10, 2024 07:48 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
andyg35c1
Aug 29, 2015 03:37 PM
ghost_g35
Aug 7, 2015 10:31 AM
joedaddy1
Jul 28, 2015 02:58 PM
