cooling & heating help
Old Sep 5, 2011 | 01:32 PM
Duriisimo's Avatar
06 G35 Sedan
Car heats up when ac is on and I am driving the car, if I turn the AC off temp goes down to normal...When stopped ac works fine and car does not heat up. I changed the thermostat, still doing it. Also ac does not blow hot air(heater). Plenty of coolant in car.
Any idieas? thanks
***Heater ONLY works when the car is moving, blows cold air when stopped, even when I put the temp up to 90***
Old Sep 29, 2011 | 01:03 AM
NISMO500's Avatar
You might have air in the system
Old Sep 30, 2011 | 05:27 PM
Vegas4DR's Avatar
I would bet that you have trapped air in the system
Use the bleeder valve on passenger side of the engine (towards battery compartment)
OR
Use the Lisle spill-free Funnel - it works great and very easy to purge air from the cooling system
Old Oct 2, 2011 | 09:27 PM
AARONHL's Avatar
Check for leaks on the bottom edge of the radiator if bleeding doesn't help.
Old Oct 5, 2011 | 03:12 AM
bythabay's Avatar
Originally Posted by nismo500
you might have air in the system
+1...
Picture Share
Feb 4, 2018 12:41 PM
DRG35R
Jan 31, 2016 07:14 AM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
