Yellow Exclamation light?
Old Dec 20, 2004 | 10:08 AM
703g35's Avatar
On my way to work this morning a yellow exclamation mark inside a half circle turned on in my gauge cluster and started beeping. Anyone familiar with this light? i'm at work so i havnt had a chance to look in the owner's manual, but im sitting here worried its something critical.
Old Dec 20, 2004 | 10:19 AM
roneski's Avatar
Devil's Advocate
Sounds like the tire pressure monitor. Nothing to worry about, just check the air in your tires.
Old Dec 20, 2004 | 12:02 PM
G35Rush's Avatar
low tire pressure
happened to me a couple months ago and i thought it was just the cold weather so i put more air into the tires. after a couple days it came back on so i put more air in and more air in...and more..
long story short, i had a nail in the inside of my tire. $250 down the drain cause of a dumb nail..
Old Dec 20, 2004 | 01:41 PM
annual's Avatar
I thought it'd be your oil temp not going up. I had the same problem 2 times...Im probably wrong.
Old Dec 20, 2004 | 03:11 PM
Msedanman's Avatar
O.F. Administrator
For sure the low air pressure warning.
Low oil temp/coolant temp would trip a Check Engine Light.
C.
Old Dec 20, 2004 | 03:17 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
If you have aftermarket wheels and did not transfer the tire pressure sensors to them, this will happen. To fix it, just turn your car off, then back on, it'll reset.
Old Dec 24, 2004 | 04:53 AM
shawnmalhotra's Avatar
low tire pressure
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
FRUG35
Aug 25, 2015 09:40 PM
Tukeeg35
18 Inch
Aug 25, 2015 06:45 PM
realtalk21
Jul 20, 2015 09:07 AM
