Help,,car wont start! :/ 2005 G35 coupe
Old Oct 24, 2011 | 02:17 AM
nelbarr's Avatar
Exclamation Help,,car wont start! :/ 2005 G35 coupe
Hi everyone, I am new to this forum and just encountered a problem with my 05 g35 coupe, manual transmission. I decided to change the spark plugs and before i started I followed a DIY spark plug threads and I went ahead and removed the battery cables negative and positive first then went ahead and removed the bolts to get to the spark plugs. I finished putting in the spark plugs and all bolts and went ahead and plugged the battery terminals but my car wont start now! :/ my battery is good because the radio, interior lights work fine, can anyone please help me out? I would really appreciate this so much, thanks.
Old Oct 24, 2011 | 08:59 AM
Z1Motorsports's Avatar
Can you give more description of whats happening, you say it won't start but is the starter turning over? Or is it just clicking?
Old Oct 24, 2011 | 06:46 PM
nelbarr's Avatar
There is no crank or clicking noise at all, all you here is the computer turning on, interior and dash lights work, fuses and ground wire from battery is good, but no start up :/
Old Oct 26, 2011 | 09:29 PM
CG4DR's Avatar
have someone hit the starter while you try to start it. sounds like it might be locking up or you have another issue
Old Oct 26, 2011 | 09:35 PM
ch1215g's Avatar
check your fuses....
Old Oct 28, 2011 | 09:20 AM
+1 Fuses, or the main wire coming of the + battery terminal that goes to the alternator/starter.
Goodluck!
-Rob
Blakelyg35
Aug 15, 2015 12:12 PM
kenthung
Jul 21, 2015 05:56 AM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
quickspeed6
24
Jul 15, 2015 11:06 AM
