Are 14935-AM60B and 14935-JF00B interchangeable?
Old Oct 24, 2011 | 12:09 PM
neptune's Avatar
Hi everyone!
I've been getting error code P0455 for a while and found 14935-AM60B solenoid valve may need replacing.
Just wondering if I can use the newer design 14935-JF00B instead? Will it fit and work fine?
This is for a 2006 G35 6MT sedan.
Thanks
Old Oct 24, 2011 | 12:59 PM
Z1Motorsports's Avatar
Originally Posted by Tech Bulletin
NTB09129 - SB Vent Control Valve Replacement
SERVICE INFORMATION When replacing the EVAP canister vent control valve for any reason: -Use the one listed in the PARTS INFORMATION section of this bulletin on Page 2. -For vent control valve replacement procedure, refer to the appropriate section ofthe Electronic Service Manual (ESM) if needed. -When installing the new valve, do not add any lube to its o-ring. -For Frontier (D40 series) only: install the protector listed in PARTS INFORMATION. --For protector installation, see the SERVICE PROCED URE section of this bulletin starting on Page 3. -Make sure to use the "new style" valve listed in PARTS INFORMATION.
Old part #: 14935-AM60B
New part #: 14935-JF00A
Goodluck!
-Rob
Old Oct 24, 2011 | 01:02 PM
neptune's Avatar
Thanks.
But can the new part be used in place of the old one?
infinitipartsusa.com doesnt list 2006 G35 under the new part's applications.
Old Oct 24, 2011 | 01:15 PM
neptune's Avatar
I guess I will also ask about install DIY guide if anyone's got it please.
Thanks
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
doakley92
Sep 25, 2015 12:58 PM
Jeff92se
Jan 8, 2008 09:39 PM
boinger
Nov 9, 2006 11:08 PM
RaleighNC
Sep 4, 2005 07:20 PM
