Need help!....possible belt issue?
Old Nov 19, 2011 | 02:00 PM
M35TheTruth's Avatar
Woke up this morning to hear this lovely sound. 2006 M35. Seems like it's one of the belts, but I am not sure which one. I did change one of the belts a few summers ago so I am not sure if it would go bad that fast. Any ideas and if it is one of the belts, is it ok to drive on at least until I can get it fixed? Thanks.
Old Nov 21, 2011 | 05:49 AM
mikhaelbt189's Avatar
no way belts will make that sound.. man, that sounds horrible! check engine oil if its in proper level? also it sounds like someting loose.. try to tighten all the pulleys.
Old Nov 21, 2011 | 12:28 PM
Vegas4DR's Avatar
Definetely is not a belt. Belts SQUEAL when they are loose or need replacing.
Hopefully that sound in not internal engine knocking. It sounds like you have a drummer in your engine bay.
make sure that nothing is sticking into the belts or pulleys
check oil level
you don't have a check engine light do you?
Old Nov 21, 2011 | 02:35 PM
Z1Motorsports's Avatar
Check your oil, but unfortunately it sounds like your engine is toast
-Rob
Old Nov 21, 2011 | 02:38 PM
No check engine lights.....very low oil level. No leaking or burning of oil.
Old Nov 21, 2011 | 02:53 PM
My guess would be a spun rod bearing
-Rob
Old Nov 29, 2011 | 04:18 AM
Got to the shop and it was......a bad belt lol. The AC belt had split in half, half away around the circumference of the belt which was the sound in the video (the split part was off the pulley hitting things). All new belts, oil change and $260 later, the M is running like a champ. Thanks guys for all your help
Old Nov 29, 2011 | 09:42 AM
Good to hear! I guess nothing can replace a first hand inspection, that video sounded nothing like a belt slapping to me lol
-Rob
k67p67
Engine - Power Adders
Aug 29, 2015 08:19 PM
EricF
Aug 28, 2015 08:27 AM
G35CO
Aug 25, 2015 02:00 PM
D1dphresh
Aug 7, 2015 06:10 PM
wuppiedog
Aug 7, 2015 11:16 AM
