Oil Pump
Old Dec 11, 2018 | 07:01 PM
Blue Dream's Avatar
I drove ttrank's car solo
Kevin since you replied to a 7 year old thread the OP is long gone and won't ever see this. But thanks for trying to help, your post might send someone else with issue in the right direction.
Old Dec 7, 2020 | 01:59 PM
Josee's Avatar
Infinity G35 Sedan
So I know I’m 2 years late on this but I got an 04 sedan & it makes this rattling noise when i first move it meaning shifting 1st gear to 2nd & it only does it once it won’t do it again after that any ideas?
Originally Posted by Kevin Larsen
hey do yourself a favor change your oil galley gaskets they are paper and cause pressure loss pumps rarely fail on these cars. the gaskets are located under your timing cover you will need to take the time cover and the upper oil pan off and thw you will see a almost y shaped channel its easy to do and you dont have to **** with your timing
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
Hogbone
Sep 28, 2015 06:44 PM
