Changed alternator, now car won't start
Old Dec 10, 2011 | 07:52 PM
nismo714's Avatar
I brought my 20003 sedan into a local autoshop to to replace my alternator, alternator/ac belts, and battery a few days ago.
Everything is fine until earlier today when the car would not start, it didn't even turn over. on the "ON" position, nothing happened, and when I turned the key all the way to start, there seem to be a jolt of electricity (interior light flashed on and off), then nothing.
After 4 failed attempts, the car finally decided to start again.
What do you guys think is causing the issue?
Old Dec 11, 2011 | 10:17 AM
snowtrax's Avatar
Starter motor?
Old Dec 11, 2011 | 10:27 AM
faiz23's Avatar
Check Crank Position Sensor which is known to go bad and make sure all connection to alternator and battery is tight and clean. Also ensure all fusable links and main fuse on battery / fusebox in front of battery and fusebox behind battery is all good. I would take it back to the shop and have them diagnose the issue since it started after the alternator install.
Old Dec 12, 2011 | 12:15 AM
nismo714's Avatar
It turned out the "autoshop guy" did not tighten the connector bolt to the battery. UNBELIEVABLE how he can forget such a simple thing.
chinee
Jun 10, 2024 07:48 PM
ClwMike
Jul 23, 2015 12:55 PM
kenthung
Jul 21, 2015 05:56 AM
realtalk21
Jul 20, 2015 09:07 AM
