My 0-60 Times...Is this Normal?
Old Dec 21, 2011 | 01:04 AM
keithk831's Avatar
My Setup:
2006 G35x 5AT
MD 5/16" Spacer
SxExCx Grounding Kit
Z-Tube
Air Temp: About 40 degrees
I'm getting 0-60 times of between 7.55 and 7.64 (based on Cipher's readings). Road and Track tested a 2006 G35x at 5.9 seconds 0-60. I know i'm not anywhere near sea level, but that seems like a pretty big difference. Is something wrong?
I bought my car this summer and since then I have replaced the spark plugs, air filter, transmission fluid and filter, sea foamed the engine, and run injector cleaner a couple times. Running Mobil 1 oil. I can't really think of anything else that might be holding me back.
Old Dec 21, 2011 | 01:47 AM
Vegas4DR's Avatar
Elevation is an absolute killer, I used to live in salt lake and know a bunch of guys that roll with g35 and 350zs...you need real power adders to be fast
You can try running with some of them and compare to get a real feel of normalcy. I will be up there during Christmas as well, feel free to hit me up
Old Dec 21, 2011 | 02:30 AM
seymore4's Avatar
m56
look into an uprev dyno and transgo shift kit
Old Dec 21, 2011 | 03:01 AM
thescreensavers's Avatar
Mr.202?
At 4500ft your loosing anywhere from 15-20% power
Old Dec 21, 2011 | 10:17 AM
keithk831's Avatar
I'll actually be in Vegas and St George during Christmas. Maybe i'll bring my cable and do a pull down there.
Old Dec 21, 2011 | 10:18 AM
keithk831's Avatar
I'm not asking how to go faster; i'm asking if my car is running the way it should at my elevation. In other words, will be 7.5 second car be a 5.9 (or faster) second car at sea level.
Old Dec 21, 2011 | 11:13 AM
alfhasg35's Avatar
well. if you are losing 15-20% from being at that altitude, seems right to me..
Old Dec 21, 2011 | 05:07 PM
Z1Motorsports's Avatar
Sounds about right, only solution for altitude is BOOST!
-Rob
Old Dec 21, 2011 | 05:28 PM
VQ35 revv's Avatar
^^as above
4500ft.... Calgary my city is around 3500 ish. NA cars suckkkkk at altitude. Only way to make power is boost. The pressure in calgary is 89kpa, and sea level is 101.3kpa. I bet your city is close to 87kpa lol.
Old Dec 21, 2011 | 08:20 PM
keithk831's Avatar
Thanks for the input! After doing some more research, it sounds like an X does 0-60 in 5.9-6.4 seconds, which is quite a spread. Then with altitude correction, i'm probably right where I should be.
Thanks!
Old Dec 27, 2011 | 09:45 PM
CBRworm's Avatar
20 Year Member
Yeah, I think a stock G35x that is running 5.9 seconds is a perfect run under perfect conditions. One of those magazine tests that is rarely matched in the real world.
Old Dec 28, 2011 | 08:26 PM
keithk831's Avatar
Well I just returned home from Vegas today. While I was down there, the car did seem to have a lot more power...more so than the increase in power I noticed in my Subaru when I went down to SoCal a couple years ago. I didn't do any logging, but i'm thinking everything is just fine.
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
aaron3719
Sep 29, 2015 10:12 AM
vamarris
Sep 26, 2015 12:56 PM
