Radiator fluid leak
Old Dec 22, 2011 | 12:24 PM
EMG03's Avatar
Radiator fluid leak
Recently there has been a small leak on the top part of the radioator that sometimes leaks down and gets sprayed all over the engine! I think it may be the clamp that goes on the hose next to the cap that is not tight enough but im not sure. Has anyone had this issue before?
Old Dec 22, 2011 | 06:10 PM
Z1Motorsports's Avatar
We have seen spring clamps fail over time and begin to lift when the system is pressurized, I suggest finding a pressure tester to pump up the system and find you leak. If it is around that clamp then replace it with a worm clamp.
Let me know if I can help with anything!
-Rob
Old Dec 28, 2011 | 08:12 PM
EMG03's Avatar
Thanks Rob, I replaced the clamp and cleaned off the radiator area, im gonna monitor it the next few days hopefully that takes care of it. Thanks again
BradMD_96
Oct 6, 2015 09:31 AM
AL8782
Oct 3, 2015 10:26 AM
Jay123
Sep 28, 2015 08:42 PM
vamarris
Sep 26, 2015 12:56 PM
