Advice for Fellow G35 Owner
Old Jan 5, 2012 | 04:46 PM
Ghostfaced1's Avatar
Hey Guys,
Im gonna try to take a slightly different approach than the usual poster. Instead of asking what is the best and what is what is what is what is....im gonna make some statements based on the research i have done before writing this post, and then you can just correct me if I am wrong.
2003 6mt G35 coupe, non-rev engine, ready to pull the trigger on a plenum spacer asap, just need a little help, and yes, i have used the search feature, many, many, times. Gonna be brief and to the point.
After doing research, can you please tell me if these conclusions are accurate. It may seem like a waste of time to you, but when it's your money that you are about to spend on something, it feels good to get some confirmation from the people on this website before pulling the trigger.
There is really no difference between a plenum spacer and a plenum (crawford, kinetix) in terms of producing power on a 2003 6mt non-rev, NA motor? And so, they are more or less considered equal...in terms of adding power
A spacer is for an OEM plenum only
If i live in cold weather, New York, buying a plenum spacer that is iso thermal copper is NOT a recomendation, it is requirement
This is one i have researched and found answers on both sides....can I keep the stock strut bar with the 1/2 spacer? Why would anyone want to remove the strut bar to fit a plenum spacer? Wouldn't the Handling be much worse?
I also had difficultly finding a concrete answer to will my engine cover fit with the 1/2 spacer.
It is pointless to buy the MREV2 manifold because I do not have the revup motor.
I do not need to also buy the manifold spacer or the aramid gasket, iso themral upgrade, from motordyne? Like, in addition to the spacer I am about to buy. Do those components add any hp or just prevent it from being robbed via heatsoak?
And this question I did not research...im just asking it...again...no research...just winging it....
Where should I look for the best price on the Motordyne iso thermal copper plenum spacer?
Thanks for your time, I appreciate it.
Old Jan 6, 2012 | 06:44 PM
CheeWho?'s Avatar
As far as I can remember, some aftermarket plenums do offer a little more HP, but I prefer the OEM one w/ a spacer.
Yes, yes they are.
If i live in cold weather, New York, buying a plenum spacer that is iso thermal copper is NOT a recomendation, it is requirement.
These two ask the same thing pretty much. The ISO thermal is recommended to prevent heatsoak. Doesn't add any more HP, doesnt take any away. I run just the spacer, but then again I live in Hawaii, so I dont have to worry about winter time snow and stuff
Strut bar, no engine cover, yes. Strut bar AND engine cover, no.
I've seen people gain some HP running MREV2's on non rev-up motors. Not pointless at all, but not necessary. Maybe money that could be spent on something else.
This one is easy. Check the marketplace. People selling their's in the private classifieds all the time, and the Vendors offer great prices too
. Wow, that was alot haha. Hope I could help.
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
laksjd84
Jul 24, 2015 05:12 PM
