Valve Cover Gaskets
Old Jan 29, 2012 | 09:41 PM
ryanm8's Avatar
Surprisingly, I had no oil at all in all 6 spark plug chambers. Guess my O-rings are still fine
Old Jan 30, 2012 | 04:22 AM
chopsuey04's Avatar
Thanks guys for the tips and advice, one last thing. does it matter how long I let the RTV dry and set?
Old Feb 7, 2012 | 09:03 AM
kpowe1's Avatar
i have to do this soon my valve covers are leaking. Did you run into any problems
Old Feb 7, 2012 | 11:09 AM
chopsuey04's Avatar
The only thing that was a pain was removing the back bolt on passenger side cover and I did learn that the job is way easier with an extra set of hands once it comes down to pulling off the covers. It took me and my buddy a total of 5 hrs but if I had to do it again I'm sure I'd take less that 2hrs. Good luck to you man.
Old Feb 7, 2012 | 11:17 AM
redpearl99's Avatar
you should let RTV set for 24hrs before full use
Old Feb 7, 2012 | 02:54 PM
o3LRG's Avatar
The same thing happened to my 04 coupe. The hardest part I see about changing the valve covers is accepting the price of the parts. I keep reading every where I have to change not only the gasket but the both valve covers and that totals up to about $750 at Infiniti and 550 at Nissan.
Holy ****! thats expensive prices. I just paid around $380 for 2 valve covers and gaskets at Nissan.
Old Feb 10, 2012 | 12:19 AM
03GT35R's Avatar
Same here! NO OIL at all in any of mine!
Old Feb 10, 2012 | 12:21 AM
03GT35R's Avatar
You can just change the valve cover gaskets without changing the complete covers. I just did it.
Old Feb 10, 2012 | 08:08 AM
kpowe1's Avatar
I asked the dealer the other day about the reasoning behind replacing the valve cover and not just the gasket, the dealer stated that the covers were plastic and that sometime they could warp and start leaking do to the heat. To prevent the dealer from having to go back and do the work twice if the covers were warped they just replace the covers to ensure the valve covers want leak.
I was going to just replace the valve cover gaskets but now I may replace the covers I dont want to do through this problem twice and with my luck my are warped.
Old Feb 10, 2012 | 11:04 AM
onevoice's Avatar
How much oil are you really burning?
Also look on ebay before buying the VCs from the dealer. I found mine for $75 online for both covers and gaskets a couple of months ago
Granted that was a steal, you'd still get them cheaper there than the dealer
Old Feb 10, 2012 | 11:35 AM
kpowe1's Avatar
cool will do
Old Feb 10, 2012 | 11:49 AM
ryanm8's Avatar
I don't buy the story about the valve covers warping... I just had mine off and they looked completely fine. It's just the gaskets that go.
Old Feb 10, 2012 | 11:52 AM
JaE35's Avatar
Moderator
G35 Sedan
exactly and you can buy the modified gaskets from a vendor on here to repair them yourself
Old Feb 10, 2012 | 12:27 PM
kpowe1's Avatar
whats the modified gasket
Old Feb 11, 2012 | 12:19 AM
  #30
03GT35R's Avatar
224k miles and valve cover gaskets were the first leak on my car...Replaced just the gaskets & my valve covers were fine...I call BS on the warping, unless you overheat your car to the point it warps them, In which that would be pretty damn hot & you would most likely damage other parts as well...I think the dealer is wanting to sell some parts & labor to you.
