valve guide seals
Old Jan 17, 2012 | 08:17 PM
13thirteen13's Avatar
valve guide seals
so i have been having the infamous oil comsumption issue and im wondering if anybody has ever replaced valve guide seals. my buddy had his replaced on his 350z and it solved the problem for him. the parts are only like 30 dollars. but ive heard the work is fairly indepth. just looking for some input/opinion on this
thanks
Old Jan 18, 2012 | 02:47 PM
onevoice's Avatar
I believe for our cars they are built into the Valve Covers so you can't really replace just the seals. There is a 3rd party vendor that sells the o-rings that you can glue on but not sure how effective it is.
However, having said that please provide details on how much oil is your car consuming. Leaky valve covers wouldn't really cause a lot of oil loss but worn rings will because that would lead to oil entering the combustion chamber and being burned off.
Old Jan 18, 2012 | 02:51 PM
im currently burning around 1/4 to 1/2 a quart a week so i basically check my oil every day i have to work and dont drive any where else unless i really need to. im going o be pulling my plugs this weekend to see if i have oil on them. my issue is that if it is the rings fixing it doesnt seem worth it to me and im stationed in germany and getting a new engine is going to be an issue for me. so im not sure what to do right now.
Old Jan 18, 2012 | 03:08 PM
onevoice's Avatar
Your car is in Germany right now?
Yes that is a lot of oil... as much as I was consuming (mine was probably more) and it turned out to be broken piston rings that caused my oil to be burned off.
I am getting my engine replaced as we speak.
You also might want to get a compression test done (if it isn't too expensive in Germany). That will at least confirm whether or not you have a valve/piston ring problem
Old Jan 18, 2012 | 03:10 PM
onevoice's Avatar
FYI - my car ran fine with the oil consumption for about a year and half to 2 years. I just had check my oil levels on a weekly basis.
Old Jan 18, 2012 | 04:49 PM
im stationed in germany im in the military and i will be here until 2015 so ill be here for a hot minute and im going to look into getting a compression test. but if it is the rings i guess im going to plan on gettig a new engine or ride dirty and check my oil weekly haha idk about that one thats alittle to shady for me
Old Jan 18, 2012 | 05:29 PM
onevoice's Avatar
lol shady and expensive. Towards the last 2-3months I was down to buying a 5QT can from Walmart every 2 weeks. I didn't even bother with synthetic stuff and just bought $12 Mobil 5000 oil.
I was spending about a $1 on oil for every gallon of gas.
Get a compression test asap just to see if you are burning oil
Old Jan 18, 2012 | 06:37 PM
well im definetly not leaking it any where externally and its not mixing with any of my other fluids but i also dont have black exhoust or anything which is a common symptom of burning oil
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
BradMD_96
Oct 6, 2015 09:31 AM
