Rev too high?
Old Jan 29, 2012 | 07:05 PM
Oklahomie22's Avatar
Rev too high?
rtyetyuery
Old Jan 29, 2012 | 07:10 PM
Sylvan lake V35's Avatar
It should be fine, the car has a built in rev limiter that will cut the spark if you rev to high it will seem like a studder or back fire if you hit it.
Old Jan 29, 2012 | 07:12 PM
yea i felt it kick back a little bit, is that what that probably was?
Old Jan 29, 2012 | 07:15 PM
also I was in manual mode if that makes a difference, and I did feel that kick back a little bit
Old Jan 29, 2012 | 07:36 PM
herrschaft's Avatar
Duplicate threads are not necessary
Old Jan 29, 2012 | 09:37 PM
ryanm8's Avatar
You have a RevUp engine... It revs to 7000 rpm lol. 6500 is fine.
Old Jan 29, 2012 | 09:42 PM
thescreensavers's Avatar
Mr.202?
False
He has an Automatic so he has the normal DE, which has a redline of 6800.
OP your not stretching the legs out enough, I hit the limiter frequently lol
Old Jan 29, 2012 | 09:46 PM
onthe3rdday's Avatar
With the automatic, the car wont let you overrev. It won't drop a gear unless it's in a safe range and as was stated earlier if you peg it their is a cutoff to prevent overrev.
ryanm8's Avatar
Ah, it sounded like he had a 6mt. Either way, 6500 rpm is fine.
Old Jan 29, 2012 | 10:27 PM
ediitttt: 7500rpm ish
Old Jan 29, 2012 | 10:28 PM
Mr.202?
^ so now you went higher? lol Your fine, the Tach is funny sometimes. It really never went over 6800.
Old Jan 30, 2012 | 08:41 AM
herrschaft's Avatar
Thats impossible on a stock car.
Old Jan 30, 2012 | 12:16 PM
oehtHuxtable's Avatar
your car is obviously fine... but leave it in D and respect your G
Old Jan 30, 2012 | 12:29 PM
bluedevils95's Avatar
Your car will be fine. I've been in the red several times and my car still running good. I am talking about 8200 2x and 7800 once in the 4 years i had it. Just try to stay out of the red. I hear you can do a lot of damage to it if your in the red a lot.
Old Jan 30, 2012 | 12:34 PM
gio9oh9's Avatar
AHAHA worst case scenario your car blows up .......your car is fine as long as you remembered to change gears obviously it was ok to have it to rev up to 6500 if it doesnt redline until 7000rpm
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
mbe32
Nov 13, 2015 11:09 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
vamarris
Sep 26, 2015 12:56 PM
