Slip & VDC light & Stalling out???
Old Feb 3, 2012 | 11:58 AM
03GT35R's Avatar
Hey guys, Need some insight on this one.....
I have never had any issues at all with my 03 G35 automatic Sedan. I was driving in a straight line about 40 mph yesterday and then the vdc & slip light came on & then the rpms dropped and engine stalled out. coasted into the center turn lane, put it in park & it restarted, lights were still on the dash & noticed that it appears to be in limp mode as it will not go over 2500rpms. When you try to accelerate over 2500 rpms it seems to be pulling timing out or like hitting a fuel cut. I was thinking that the slip & vdc light may be coming on bc of a bad wheel speed sensor.
Have any of you had this happen before?
Old Feb 3, 2012 | 03:31 PM
03GT35R's Avatar
come on guys, anyone?
Old Feb 3, 2012 | 06:51 PM
Da-G-SpoT's Avatar
MAF is disc or gone bad. Check it, its right after the filter on your intake tube.
Old Feb 3, 2012 | 11:53 PM
03GT35R's Avatar
by "disc" do you mean disconnected? and the maf would cause the slip/vdc to come on?
Old Feb 3, 2012 | 11:56 PM
03GT35R's Avatar
Drove the car today, slip & vdc lights were not on, but still wont go over 2500rpms, and the MAF is connected. Since the car has stalled a few times, i havent seen a CEL come on at all. I think if the MAF was bad, it would throw a code....
Old Feb 4, 2012 | 08:27 PM
03GT35R's Avatar
Update-
plugged into a scanner today & found that my CEL (bulb in cluster) malfunctioned (or burned out) The reason for the stalling, and not hitting over 2500rpms was bc it was pulling CAS (cam angle sensor) codes & put it in fail safe mode. I reset the codes, and and so far so good. No slip, or vdc has came on & the motor is going well over 2500rpms now....
Old Feb 5, 2012 | 04:43 PM
Theory_EK's Avatar
It is the driver side cam sensor going out. There is a TSB on it take it to dealer and they must fix it for free. It will come back and it will do it again.
Old Feb 8, 2012 | 01:15 AM
thechiguy's Avatar
^ had this same exact problem, replaced sensor in minutes and no problems since
Old Feb 9, 2012 | 11:33 PM
03GT35R's Avatar
Just read your post...Thanks for the info...It didnt it again today...not revving up over 2500 rpm's...Man that crap pisses me off when i m needing the power! I doubt mine will be covered under warranty, bc i have a crap load of miles...The dealer is over an hour away from me, so for now & until i can get the part to replace it. I will just reset the codes again.
Old Feb 10, 2012 | 06:58 AM
Theory_EK's Avatar
Well I would recommending doing both at the same time it cost me 160 bucks for both.
Old Feb 10, 2012 | 12:00 PM
03GT35R's Avatar
yeah when i get around to getting the parts, i will def do both at the same time...
Old Mar 2, 2023 | 11:55 PM
Jayro7777's Avatar
2008 G35X Sedan
Idk what to do next!!!
​​​​​​I was having the same issue. My G35X would stall out while making a turn in reverse, or also when making making a turn from being stopped at a traffic light or stop sign. I took it to the nearest Infiniti dealership and they charged me $170 just to look at it and tell me that there wasn't anything wrong, and cant see any problems with it. They also told me that when hooked up to the reader, no codes are popping up. I finally stopped at an Auto Zone to plug it in myself and the Codes for a bad CPS (Camshaft Position Sensor) was popping up so I replaced all 4 sensors. The stalling seemed to be no more but the check engine light would still come on and stay on. Now after about 9-10 months later it is happening again just like before but now it's stalling out more frequently.
Old Mar 3, 2023 | 10:56 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Pull codes and post them.
If it's stalling when you're turning the steering wheel while parked that's probably the power steering pressure switch. Your rpm should flare just slightly when you turn the wheel, if the rpm's fall then the switch is probably failing and not telling the ECM to raise target rpm to compensate for the drag on the engine from the PS pump.
Mry
Mar 3, 2023 01:03 AM
Luisgalvan33
Jul 19, 2018 08:16 PM
MsFitFern
Aug 9, 2015 02:58 PM
Luisgalvan33
Jul 28, 2015 05:37 PM
Wayne9011
Jul 27, 2015 11:25 AM
