Vegas Heat = Need options for better cooling !!
Old May 3, 2012 | 03:36 AM
DrivenG's Avatar
So i have noticed when i come to a stop my fans are roaring. Vegas gets hot and I've had bad luck with cars over heating.
Any suggestions on cost effective cooling mods i should look into
05 Sedan 6MT
Thanks
Old May 3, 2012 | 03:49 AM
mikhaelbt189's Avatar
yea change your radiator to mishimoto or koyo or something similar, put water wetter coolant additive and get the racing thermostats.
Old May 3, 2012 | 03:55 AM
the only cheapest thing that you might try first is to use the water wetter additive. you can buy it in most autoparts in your city.
Old May 3, 2012 | 04:03 AM
DrivenG's Avatar
I might just upgrade to a mishi and use the stock fans.
Old May 3, 2012 | 04:05 AM
Jairen's Avatar
DO NOT mix water wetter with normal coolant.
Search for water wetter and brown sludge. It gets nasty.
Old May 3, 2012 | 04:15 AM
DrivenG's Avatar
I stick with regular coolant always
Old May 3, 2012 | 01:12 PM
Silencer_0's Avatar
Aftermarket radiator and fan shroud.
Old May 4, 2012 | 02:41 AM
Tolboothwilley™'s Avatar
What kind of coolant is recommended with the water wetter? I never heard about this bit noticed a little of what you are talking about. never heard about it before though
Old Mar 11, 2013 | 07:17 PM
found this image
RedLine Water Wetter vs Lucas Super Coolan
notice the ALUMINUM effect - since ours are aluminum blocks this is important
Picture Share
Feb 4, 2018 12:41 PM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
