'06 Sedan won't idle
Old Jun 15, 2012 | 03:17 PM
onevoice's Avatar
oh and the battery?
Old Jun 15, 2012 | 04:21 PM
VstyLe09's Avatar
Hmm, had something like this happen to me, didnt replace any sensors though. took it into the dealer for a whole month and all they did was directly wire the maf to the ecu. Although they did fry the ecu while diagnosing it. Might be something bad with the engine harness im assuming.
Its been almost 2 yrs now and the car is running good still.
Old Jun 16, 2012 | 08:52 AM
nadjkovic's Avatar
Originally Posted by onevoice
Get a hold of yourself man and have some self respect!
Know anyone else with a G that you can use parts off of to test? Like MAF
Also have you checked for vacuum leaks? Must be a big one if you car stumbles like this.
OR could it be that you just have really bad gas?
Well, the G is up at the Gwinnett Infiniti slightly North of Atlanta now :/
Originally Posted by freakta
id check wires on the coils, if some are frayed or not plugged in all the way or grounded to somehting else... thats my first guess
coil wires were fine. thanks though.
oh and the battery?
has nothing to do with that.. I have good voltage & cranking power
Wow.. well they better inform me before they pull some Frankenstein **** on my car.
Old Jun 16, 2012 | 01:20 PM
nadjkovic's Avatar
Video! Crank up the volume. Exhaust is removed post-cat
Old Jun 16, 2012 | 01:44 PM
nadjkovic's Avatar
The SES thrown during the video is just 0603 which is from having the negative battery terminal disconnected for too long. No codes.
Old Jun 19, 2012 | 07:28 PM
onevoice's Avatar
after watching the video it definitely seems like the fuel isn't getting to the engine.
Have you tried driving it? Does it move or stalls when you put it in gear?
It might also be the throttlebody. But usually you don't hear about TBs going out all of a sudden.
Old Jun 19, 2012 | 07:30 PM
onevoice's Avatar
Is there a way to drain the fuel and put in new one? Just to eliminate the bad gas theory? But if you filled up at your usual station and put in premium then that might not really be the issue.
**** man, I feel sorry for your situation though. It sucks
Old Jun 19, 2012 | 07:33 PM
onevoice's Avatar
Oh btw did you check all the hoses for cracks and leaks? Especially the one near the MAF
Old Jun 19, 2012 | 11:13 PM
MaDMaXX's Avatar
The fuel pump is pretty easy to replace if you need to do that. It's behind the passenger seat.
Old Jun 20, 2012 | 10:19 AM
onevoice's Avatar
He already replaced that and it didn't change anything.
Old Jun 22, 2012 | 03:45 PM
nadjkovic's Avatar
OKAY! $476 later, I got the car back from the dealer. Problematic part? Fuel pressure regulator. Normally a $50 part located in the fuel pump assembly. I replaced the pump out of the assembly in a matter of 20-30 minutes. They charged me for 3 HOURS. Needless to say I'm a little frustrated, but they fixed it, and I didn't. If anyone has any questions, or related problems let me know or post here.
Old Jun 22, 2012 | 04:04 PM
JaE35's Avatar
Moderator
G35 Sedan
Wow that sucks man but happy your up and running..definitely update your first post this is great information for everyone that may possibly run into the same issue
Old Jun 22, 2012 | 08:58 PM
MaDMaXX's Avatar
Erk, so close, yet so far, right next to the pump on the same assembly, wow, that just sucks, but at last your car works now!!
Old Jun 27, 2012 | 06:45 PM
nadjkovic's Avatar
Thumbs up
Thanks, and I updated the first post!
thanks! & I KNOW -_- frustrating.. but lesson learned! I knew it was fuel related. Next time I'll believe in myself a little more and keep going.
derres
Aug 28, 2015 03:27 PM
dimentio1
Aug 16, 2015 11:47 AM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
Rehman2009
Jul 27, 2015 03:23 AM
