Low-end torque
Old Jun 27, 2012 | 06:39 AM
unfadable's Avatar
Low-end torque
I noticed that the power is not smooth all the way through the curve. From 2-4k the throttle response feels sluggish compared from 4-7k. I have basic breathing mods - spacer z-tube exhaust filter. I have some disposable income and am seeking to address this. I'm considering pulleys and a tune but wanted to get other insight. Thanks in advance.
Old Jun 27, 2012 | 12:40 PM
jiggawuah's Avatar
art pipes & osiris tune.
/thread.
Old Jun 27, 2012 | 01:40 PM
MaDMaXX's Avatar
Yeah, that ^^^
If you couple the ART pipes with an XYZ pipe it will also help, as will an MREV2, but to slowly diminishing returns.
Old Jun 27, 2012 | 05:23 PM
Silencer_0's Avatar
3.7 FD gears or shorter, 1-piece aluminum or CF driveshaft.
Old Jun 27, 2012 | 09:12 PM
jninja26's Avatar
Does replacing DS with a carbon one make a big difference...how/much exactly?
Old Jun 27, 2012 | 09:25 PM
jbwrecked's Avatar
https://g35driver.com/forums/drivetr...eshaft-11.html
Pretty sure their is a dyno in there somewhere. Get to searching
Old Jun 27, 2012 | 09:55 PM
seymore4's Avatar
m56
Replacing the driveshaft should come after all that other stuff, shoot you can't even go truely full throttle without an Osiris reflash to remove the WOT restriction... That alone will make a huge difference
Old Jun 27, 2012 | 10:14 PM
MaDMaXX's Avatar
So whilst the gears and/or driveshaft will help it be a little sharper in response, it won't change the power delivery low down.
Old Jun 27, 2012 | 10:26 PM
Silencer_0's Avatar
ART pipes and 3.7 gears made the biggest difference in low end power and acceleration for me. Aluminum DS is next for me.
Old Jun 27, 2012 | 10:33 PM
MaDMaXX's Avatar
Yup, it absolutely will improve the acceleration, but only the ART pipes will help with the smooth power production.
Old Jun 28, 2012 | 02:00 AM
unfadable's Avatar
So is the gearing done through the tune?
Old Jun 28, 2012 | 02:06 AM
Footballmania32's Avatar
No its done by the rear differential. The 3.7 Final Drive gear ratio is out of a G37/370z. You simply purchase their OEM rear differential, make sure you get the VLSD version as well. From there it is a direct swap from your OEM diff. There is a thread around here that shows you how to DIY and exactly which pumpkin you need.
frankywashere
Sep 2, 2015 01:22 AM
yosip1115
Aug 26, 2015 10:46 AM
Mattdi
Aug 23, 2015 11:27 PM
Raven7
Aug 14, 2015 04:40 PM
Ray Feta
Aug 13, 2015 11:40 PM
