Engine change in driveway
Old Jun 6, 2012 | 04:43 PM
WINTERDEVILG35's Avatar
I have a Vortech SC 03 G35 and I'm going to do an engine change with an engine from IPP. Has anyone successfully changed out their engine without the use of a vehicle lift? Apparently you need to drop the transmission and engine together from the bottom of the car and thats not possible in my driveway. I have done many diesel engine changes where I work but those applications are not cars; although, I am a skilled mechanic and I'm familiar with engine changes. The only way I can see it working is by taking off my SC, radiator, front bumper, and everything else on the front so I can have clearance to move the engine away from the transmission. Sounds possible with a cherry picker/engine hoist but I'm asking if anyone has done it before and if you have any advice. Thank you.
Old Jun 6, 2012 | 05:35 PM
HotRodG35's Avatar
I have removed/installed engine/trans twice in my G and once in a 350z(CUX350z/CUXtopher) without a lift.
Your right about removing front end/bumper/radiator/condeser/radiator support.
Recommend having AC system evacuated to completely remove condenser, it becomes a hindrance.
Old Jun 6, 2012 | 06:11 PM
As long as its possible then I'm going to do it. Thanks for the encouragement and I might make this a DIY if other people are interested.
Old Jun 7, 2012 | 10:22 AM
onevoice's Avatar
My local mechanic (who doesn't have a shop and works out of his driveway) swapped my engine and he did exactly what you said. Removed the entire front end and used a hoist to do the swap.
Its easier than it seems. Removing the front is just a simple jigsaw puzzle. Remember the order when taking the parts out (label and # would be nice) and reverse the order when putting everything back on
Old Jun 8, 2012 | 07:08 PM
Shakuya88's Avatar
Im in the process of doing it now just waiting on my engine from IPP now. Removal wasn't a problem at all.
Old Jun 10, 2012 | 10:10 AM
Anything you want to suggest before I start? Shakuya88.
Old Jun 13, 2012 | 06:01 AM
dreamweaver's Avatar
goodluck with the swap ill be swapping out my engine in a few weeks too.
Old Jun 13, 2012 | 03:46 PM
onevoice's Avatar
You know what would be awesome.
If one of you can be kind enough to document and photograph all your work and post a engine swap DIY for the rest of the forum members.
I bet you would get major props and your e-rep would reach unprecedented heights.
Old Jun 14, 2012 | 01:19 AM
GreenGoblin's Avatar
The goblin resurrection
Its not hard at all just faster with a lift. Done plenty both ways
Old Jun 14, 2012 | 12:27 PM
So it seems the only issue anyone has brought up that I need to be ready for is the condenser. Another thing I need to do is time my new engine. I have to swap my vtc gears and buy all new timing components for my new engine and put it at top dead center and ensure the cams are in the correct position before I put the chains on. Hoping that doesn't give me to much of a hassle.
Old Jun 14, 2012 | 01:04 PM
HotRodG35's Avatar
Carefully study factory service manual illustrations and you should have no issues.
Timing components are marked and easy to align.
Only problem in my build was Brian Crower cams have 1 extra locator pin that was easily removed.
Old Jun 24, 2012 | 01:02 AM
Sylvan lake V35's Avatar
I have done several swaps through the front and I have never had to touch the AC condenser. Just discharge the AC and unhook the two lines by the rad remove the entire front as one part with the rad/fans/condenser as one unit. One thing you might want is to put the car on jack stands, it gives you more room to work if you put the engine and trans in at the same time. I personally find it easier to install them together.
Old Jun 24, 2012 | 01:18 PM
Thanks for the insight. One thing you should know if you don't already is discharging R134A is illegal. LOL. If EPA were to find out you would be heavily fined. I will look into taking the entire front end off together like you said. Thanks.
Old Jun 25, 2012 | 02:07 AM
take it to a shop and have it discharged into an AC machine but thanks for the tip
Old Jun 25, 2012 | 12:19 PM
Originally Posted by careboy
I'm going to have to think about that one.
Picture didn't show up broski.
