Car Battery Randomly Dies
Old Jun 12, 2012 | 04:42 PM
Joshmg's Avatar
Hey guys I'm new here and have a quick question.
I get back home from the gym (my car is working fine), and then randomly 10 minutes later I go to turn my car on and it was completely dead. Then 10 minutes later it started fine. The same thing happened again last night and I'm a little confused on what the problem is.
There is a light on. It is a red light that has a little guy wearing a seatbelt, but it has been on for a long time.
Do you think this is just a problem with the battery? an electrical problem? I need some suggestions thank you!
Old Jun 12, 2012 | 05:05 PM
onevoice's Avatar
Little seatbelt guy is the seatbelt sign. Do you wear it while driving? It shouldn't be on if you do
If it stays on then it might be a wiring issue that is causing your battery to go bananas. It also might be your starter going out if it doesn't start intermittently. Do you hear a click when you turn the key (when your car doesn't turn on)?
2004v35's Avatar
need more info, When you say completly dead, if you turn on your lights do they light up?
the little guy w/ the seat belt light does it goe away when you put yourseat belt on?
Old Jun 12, 2012 | 08:23 PM
Joshmg's Avatar
No it does not make a clicking noise when I try and turn the key and no the lights won't turn on.
The seatbelt guy I looked up and it is the airbag censor.. so I don't know if that is related to the battery.
Does that sound like a starter issue?
Old Jun 12, 2012 | 10:29 PM
onevoice's Avatar
Then I am pretty sure its the battery. Take it to a local autozone to have it tested.
Also there is a reset procedure you can try for the airbag sign. (just search airbag/SRS sign reset) If that doesn't work, try searching for the airbag recall they had and see if your car was part of it.
Old Jun 13, 2012 | 05:34 AM
Joshmg's Avatar
Thank you for the response one voice, the reason I don't know if it is the battery is because of how random it is when it goes out. I'll be driving around, then come home, try to turn on my car 5 minutes later and it's dead, then 5 minutes later it was working again. But i'll take it to autozone tomorrow and see if it is the battery
Old Jun 13, 2012 | 06:48 AM
slim17265's Avatar
clean battery terminals
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
ghost_g35
Aug 7, 2015 10:31 AM
BlueBelleG35x
Jul 23, 2015 02:10 PM
