First Automatic Transmission Fluid Change at 90k
Old Jun 26, 2012 | 06:04 PM
srv2nv's Avatar
G35 Sport
Originally Posted by Infiniti Chica
Nissan/Infiniti's official stance on transmission flush vs. drain is DO NOT FLUSH, which came out as a bulletin in 2007 (Reference NPSB/07-027; #9376 page 3). A drain is preferred, but there are also some recommendations that dropping the pan and thoroughly cleaning it and the screen are the best way to do it. Some folks drain and fill every oil change for 3 oil changes (at the designated time), this ensures that at least 90% of your fluid will be "new" within by the 3rd regular oil change (I change mine every 7.5K using Castrol Edge or Pennzoil Platinum Ultra).
Thats interesting to know. I just got off the phone with Nissan yesterday who told me they don't do transmission drain and fills, they hook the car up to a machine with an external pump and run new fluid through the transmission (aka. tranny flush). My friend was going to go there for a tranny service and told him to go to his mechanic for a drain and fill, and save his transmission. (80k+ miles on his Maxima)
Old Jul 3, 2012 | 04:05 AM
jutn35's Avatar
G35 Coupe
I did mine around 65k, im at 80k now, but i guess it felt a tad bit smoother or maybe its just wishful thinking
Old Jul 3, 2012 | 05:49 PM
maximized98's Avatar
Did mine the other day at 67k, seems much better now.
Old Jul 10, 2012 | 10:35 PM
gary c's Avatar
Originally Posted by mrtrodonet
Hello fellow G owners,
I know this topic has been raised many times but there were very little threads for cars with high mileage like mine. I have enough of ATF fluid to drain and fill all 11-12quarts but still have some back thoughts ...
I'd like hear from people who drained and filled all the liquid at approx the same mileage and how the transmission felt after it or from those who chose not to and drained only half or so. Thanks
mrtrodonet, it would be nice if you'd let us know what you ended up doing and the results. We can go by what Nissan recommends but in a case like yours knowing how the trans service worked your input would be of great value. Just in case we have someone else that neglects to change their fluids for a gazillion miles....
Gary
Old Jul 10, 2012 | 11:27 PM
Skyline0811's Avatar
you cant flush out atf on the g's. you will have problems. Drain and fill would be the most advisable. will do mine soon at 125k, and i had friends that done a drain and fill on their g's 03-06 and had no issue.
Old Jul 12, 2012 | 02:31 PM
gary c's Avatar
Nissan recommends not doing a flush, that must really **** off the "Stealerships" that charge $300 to do that job! For those members that haven't changed there trans fluid until they get close to 100K miles I'd be interested to know the results of a drain & fill just for future members knowledge....Gary
Old Jul 13, 2012 | 12:40 PM
Groundhog's Avatar
What ATF are most of you using?
Old Jul 13, 2012 | 12:51 PM
Mr. Brett's Avatar
At 230k miles, I have no idea if the PO every drained and refilled the 5AT on my car. I would assume, having that many miles on her, he did it at least once or twice. But I could be wrong.
The tranny still feels snappy, and has nice, clean shifts when in taptronics mode. The only thing I do notice is a 2nd to 3rd gear clunk under heavy acceleration, but I'm pretty sure I've read somewhere that that's a fairly common issue with 5AT G's and Z's. So I'm a bit leery about actually doing it.
I may do a partial drain/fill and see how that goes. If I do, I'll report back to everyone, especially since my car is so high in mileage.
Old Jul 13, 2012 | 12:53 PM
Mr. Brett's Avatar
Pretty sure Nissan says that you NEED to use the Matic J fluid in the 5AT. In something as expensive and hard to repair as an auto tranny, I wouldn't use anything else, personally.
It's not something like a rear end, where if you blow it up, it's only a two or so hour job to fix.
Old Jul 13, 2012 | 05:13 PM
srv2nv's Avatar
G35 Sport
Matic J was discontinued, although some dealerships still have it, Matic S is what you should be putting in now. It can be added to a transmission that has Matic J already in it, so using it for a drain and fill should be no problem, from what I've read.
I'm at 120k miles, bought the car at 60k miles and not sure of the transmission change history. Never did a drain and fill as I've learned from the past that a high mileage transmission should be left alone.
Unfortuantly, I sprang a leak in BOTH hard lines from the transmission to the cooler, so they had to be replaced. Checked the fluid before hand and it was a clearish red, and showed up as a dark rust color on my rag. I decided to drop the pan out and clean off the magnets for the install/drain and fill...to my surprise, the magnets were completely clean! Filled up with 5 litres of Matic S and after did notice the tranny feels "firmer", and the odd hesitation, not a slip, just a hesitation with random shifts, has gone away (possibly due to the leak or degrading fluid?)
I should add that my daily commute is 90+% highway, and I do baby the car with the exception of a few spirited driving moments.
Old Jul 13, 2012 | 06:11 PM
thescreensavers's Avatar
Mr.202?
2>3rd clunk is normal, it has to do with the clearance between the direct clutch and the hi-low-Reverse clutch
Old Jul 13, 2012 | 09:43 PM
Mudgen's Avatar
I may be missing something: is there somewhere in this thread where someone mentions what car/trans we're discussing? The fluid situation is rather different from the 5 speeds to the 7 speeds.
Old Jul 13, 2012 | 11:50 PM
Mr.202?
^ We are talking about the 5AT
Whats different about the 7AT?
Old Jul 14, 2012 | 07:30 AM
Mudgen's Avatar
The official Infiniti line is that the 7AT is a sealed unit and does not require fluid replenishment or replacement. Although there is a drain/refill procedure in the service manual.
Old Jul 14, 2012 | 01:13 PM
  #30
Mr. Brett's Avatar
That's what I thought. It was just a little unnerving the first few times I heard it, because it reminded me of how the tranny on my Trans Am used to clunk right before it blew up.
