First Automatic Transmission Fluid Change at 90k
Old Jun 12, 2012 | 11:03 PM
mrtrodonet's Avatar
Hello fellow G owners,
I know this topic has been raised many times but there were very little threads for cars with high mileage like mine.
I have enough of ATF fluid to drain and fill all 11-12quarts but still have some back thoughts ...
I'd like hear from people who drained and filled all the liquid at approx the same mileage and how the transmission felt after it or from those who chose not to and drained only half or so.
Thanks
Old Jun 13, 2012 | 06:38 AM
prinny's Avatar
Might of been a bad idea to do a full flush like that if it's your first.. especially at that high of a mileage. Would of just stuck to changing out like 4 quarts or so then wait another idk.. 15k or 20k miles or so then change out another 4 quarts.
Old Jun 13, 2012 | 11:15 AM
Jhambor's Avatar
I wouldn't even bother changing it....especially if nothing is blatantly wrong with it to begin with. Good chance it will do more harm than good.
Old Jun 13, 2012 | 11:26 AM
DRVNFAST's Avatar
I have 94k on my 03 5AT and was wondering the same thing. Everything seems to work fine but I heard ppl have problems once they change the fluids out. To flush or not to flush, that is the question.
Old Jun 13, 2012 | 11:31 AM
mrtrodonet's Avatar
Well i was planing to do a drain, not a flush, lets keep this in mind. I'm not gonna add any cleaning agents and pressure. Just drain it all and fill with new one
Old Jun 19, 2012 | 07:22 PM
sticks187's Avatar
New G35 owner here in the exact same situation. Mine's at 90,000 kms and I'm planning to go for the car's first ever ATF change this Saturday.
I stumbled upon this thread and just wondering why it would be so bad to do a full change?
Old Jun 20, 2012 | 06:18 AM
prinny's Avatar
If you don't drain and replace 4 quarts of transmission fluid that often then doing a flush will definitely be a problem. Someone posted something about this awhile back..
They said that the transmission fluid gets dirty with small pieces of metal/sludge that build up over time and those pieces end up sticking to the gears and eventually get used as "grip" if not changed often. So if you haven't drained your transmission fluid at all for I guess around 50k+ miles then doing a flush would be horrible because you'd lose all those metal pieces and there would be no "grip" and it would cause the transmission to slip and you'll end up having to get a new transmission.
It's really late and im tired and it sounds retarded the way I explained it, but it works.
Old Jun 20, 2012 | 08:49 AM
gary c's Avatar
Safe way would be to drain and fill now, see how your trans reacts and again during your next oil change and you won't ever be 100% clean but way better....Gary
Old Jun 22, 2012 | 07:59 AM
Infiniti Chica's Avatar
Nissan/Infiniti's official stance on transmission flush vs. drain is DO NOT FLUSH, which came out as a bulletin in 2007 (Reference NPSB/07-027; #9376 page 3). A drain is preferred, but there are also some recommendations that dropping the pan and thoroughly cleaning it and the screen are the best way to do it. Some folks drain and fill every oil change for 3 oil changes (at the designated time), this ensures that at least 90% of your fluid will be "new" within by the 3rd regular oil change (I change mine every 7.5K using Castrol Edge or Pennzoil Platinum Ultra).
According to the Automatic Transmission Rebuilders Association, 90% of ALL transmission failures are caused by overheating. And most of these can be blamed on worn out fluid that should have been replaced. Not on lose metal parts floating in the system following a flush/drain.
Just my .02
Old Jun 22, 2012 | 09:58 AM
gary c's Avatar
Good Information....^....but sad to see that you change oil every 7500 miles. Using the best synthetic oil it only cost $60 including quality filters, that's cheap insurance to keep your engine happy and clean....Gary
Old Jun 22, 2012 | 10:45 PM
prinny's Avatar
Changing your oil every 7.5k with Castrol Edge or Pennzoil Platinum Ultra should be fine though.
$60 is a high price to pay. Usually it's like $30-$35 for a box of Castrol Edge or sometimes even German Castrol then the filter is another $10 max for a quality one like M1 or Bosch or K&N
Old Jun 22, 2012 | 11:11 PM
herrschaft's Avatar
Thanks
Thats a lot of miles to go without changing the fluid. Don't half-@ss the maintenance and replace all of the oil, you probably won't feel a difference but you will help the transmission last longer.
Old Jun 23, 2012 | 08:15 AM
And since I perform my own oil changes (plus brake and rotors, power steering fluid, brake fluid, etc.), the price is fairly cheap ($37).
Prinny or Gary C--- is there any qualitative difference between K&N, Purolator 1, MI or other higher end filters? Some Amsoil folks laugh when you ask this question.
Sorry about hijacking your thread OP.
Old Jun 23, 2012 | 09:06 AM
thescreensavers's Avatar
Mr.202?
^ K&N And M1 Filters are virtually the same, Bosch, Pure 1 are also very similar.
Wix and Napa Gold are the same filters.
Amsoil is a different filter
I am talking about internals
Old Jun 23, 2012 | 03:02 PM
Mr. Samster's Avatar
I have over 153k miles on my 04 sedan. Ive been doing a drain and fill (diff, tranny, coolant) every 30k since I got the car at 33k. I change the oil at about 4700 miles with castrol syntec and OEM filter, but on my next oil change i will be using napa gold oil filter. So far my car is running fine, never had any major issues.
