Turbo Oil Drain Line - Tap Block or Oil Pan Spacer?
Old Aug 3, 2012 | 11:08 PM
josh.irvine.6's Avatar
Hello,
I currently have my turbonetics kit draining into a pre-tapped oil pan spacer.
I am burning a good amount of oil, yet my compression is still great.. Could this be a reason? Is it better to have it tapped into the block, or should it make no difference?
Thanks
Old Aug 4, 2012 | 04:13 AM
Sylvan lake V35's Avatar
I have heard all kinds of story's on this. I had run the spacer with drain line and I never had any issues. I changed because I got an APS oil pan.
Old Aug 8, 2012 | 08:31 PM
lucid215's Avatar
im running a oilbpan spacer as well with no issues. are you blowing out any smoke? are you a 6mt or 5at?
Old Aug 8, 2012 | 09:10 PM
Yeah I'm blowing out lots of smoke, that's the problem. I look like I drive the bat mobile when I drive it hard, not cool at all. I'm 6mt.
Old Aug 8, 2012 | 09:12 PM
herrschaft's Avatar
Sounds like the seal on your turbo is bad, Turbonetics is notorious for that. Either rebuild the turbo or upgrade to a different one (non-Turbonetics).
Old Aug 8, 2012 | 10:16 PM
That's exactly what I thought it would have been initially, but if that were the case, when I took off my intercooler piping from the turbo, there should have been oil in the tubes right? But there wasn't... So doesn't that mean my seals are ok?
Old Aug 12, 2012 | 10:02 PM
How would I go about diagnosing this? I'm starting to think its my turbo seals, and not my rings... I get the bluish smoke most when I'm shifting gears or when i let off the gas during boost.. Acceleration doesn't seem to have much smoke at all.. Any ideas?
jsimonk
Dec 22, 2023 03:49 PM
linedr89
Aug 17, 2015 05:11 PM
itztwinki3
Aug 11, 2015 05:52 AM
ghost_g35
Aug 7, 2015 10:31 AM
