Vq35de oem cam and followers
Old Aug 7, 2012 | 08:29 PM
Jwrsprinklers's Avatar
Hey guys. I am new here and have owned a g35 for 7 years now. just want to hear an opinion if you have had the cams out of the de motor. It's a 03 g35 sedan. The cams are removed to replace the cam followers and I see one cam seems to be a tight fit even after the bolts are removed. The other cams slide out easily... Anyone come across this? A little scared to put the motor back together thinking he head may be warped.
Can someone tell me what would be a good idea from here? It's 130k on the motor but ran hot at one time she. The coolant tube gasket blew. Car has always had a ticking noise for a year or two ntl I decided to check he valve clearances. That's when I noticed the cam is tight after all components released.
Thanks for reading and look forward to any input. Thanks
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
whatacar
Canada
Aug 13, 2015 07:33 AM
Ashton35
Jul 22, 2015 09:19 PM
