Which Mod First ?
Old Jan 17, 2005 | 09:54 AM
TonyZ_G's Avatar
Which Mod First ?
Z Tube With K&n Drop In Filter Or The 10 Wire Gordgee Grounding Gear
Old Jan 17, 2005 | 01:38 PM
roneski's Avatar
Devil's Advocate
I'd say the Z-tube with the filter. Between the sound and the slight power increase the results will be more noticeable. Not that the grounding kit isn't worth it, I have a kit and I do acthally think that it made a difference with my shifting.
Old Jan 17, 2005 | 01:44 PM
TonyZ_G's Avatar
i was leaning toward that too, but then i was thinking what if i later i decide to get the grounding kit and he doesnt offer it so cheap anymore you know
Old Jan 17, 2005 | 02:03 PM
jayco's Avatar
get Z tube with the K&N. IMO grounding gear is RIDICULOUSLY overpriced. you can go to home depot and buy the same guage wire & ring terminals for < $20.
Old Jan 17, 2005 | 02:48 PM
jjellyneck's Avatar
Z tube should be first. Add the K&N air filter when the stock one gets some miles on it--you won't notice a whole lot from the filter.
With that said, now you need to look at your next mods! Consider:
high flow cats
plenum or plenum spacer
exhaust
UR pulley
etc.
Old Jan 18, 2005 | 12:49 AM
Mach 5's Avatar
what is this Z tube i keep seeing everywhere? can you help understand exaclty what it is?
Old Jan 18, 2005 | 02:48 AM
aam6906's Avatar
Screw The Z Tube, i would go with an Injen CAI, i love mine, made the car BREATHE!
Old Jan 18, 2005 | 02:51 AM
lucidazn's Avatar
Nismo CAI!
Old Jan 18, 2005 | 08:38 AM
roneski's Avatar
Devil's Advocate
The stock airbox breaths just fine and in many cases better than many aftermarket CAIs. No one has been able to prove otherwise.
Old Jan 18, 2005 | 01:34 PM
GZire's Avatar
I'd keep the stock air tube and filter and spend the money on a Crawford plenum.
Old Jan 18, 2005 | 01:41 PM
lucidazn's Avatar
Or you can wait for the APS plenum coming out mid-march.
Old Jan 18, 2005 | 06:43 PM
INTENSEPOWER's Avatar
GReddy Twin Turbo!!!!!
Old Jan 19, 2005 | 01:41 AM
aam6906's Avatar
get the Crawford Plenum and an Injen CAI, its worth it, and it isnt that expensive........$550 isnt that much
Old Jan 19, 2005 | 05:18 PM
Tfasano's Avatar
I think we should be asking him what transmission he has because I would suggest getting the Torque converter done if it is an auto, and the flywheel if it is a MT.
Old Jan 19, 2005 | 06:26 PM
k0305's Avatar
do they have torque converters fot the AT?.....if so where can you get it?
