07 g35 need help on a tune up
Old Aug 24, 2012 | 10:52 PM
Motoman360's Avatar
Did a tune up and after it put a multiple cylinder misfire code, I can hear it misfiring in the exhaust it sounds horrible. Not sure where to go from here any one have any ideas ? Only work done was new plugs seemed simple enough
Old Aug 24, 2012 | 11:51 PM
kristinavq's Avatar
this happend to me i pulled the plugs baq out and put them back in again and it was fine . Make sure all connectors are attached correctly also make sure everything torque down enough also did you check the gap ??
Old Aug 25, 2012 | 12:00 AM
jninja26's Avatar
Did you complete one plug change at a time? Make sure each plug harness connected back, to plug it was pulled from? Disconnect battery terminal before doing plugs?
Old Aug 25, 2012 | 12:01 AM
Motoman360's Avatar
Ya checked the gap .45 if I recall plugs matched the old ones I actually did repull the caps back off and sprayed them out with throttle body cleaner and re attached them but still misfires I guess the only step now is to get new plugs and replaces them all and see if that fixes it. Other than that I don't no what could be an issue
Old Aug 25, 2012 | 12:02 AM
Motoman360's Avatar
Did not disconnect battery before did plugs is that an issue ?
Old Aug 25, 2012 | 12:05 AM
jninja26's Avatar
It would've made much more sense to use MAF cleaner, than TB cleaner.
Even if you think you did, recheck that everything is hooked back up.
Old Aug 25, 2012 | 12:07 AM
jninja26's Avatar
I forgot why you're supposed to but you are. I believe it could short something if batter is not disconnected prior.
Old Aug 25, 2012 | 12:09 AM
Neal376's Avatar
just an FYI
I had a misfire. opened uprev and found out i was running 110-120% fuel trims. replaced fuel entire fuel pump assembly with junk yard unit for cheap, and everything is good now. the filter on my second gen car is within that assembly, I wouldnt doubt mine was occluded. make sure you classify your misfire as lean or rich type before you go diving in.
Old Aug 25, 2012 | 12:15 AM
jninja26's Avatar
Cipher is a good tool.
Old Aug 25, 2012 | 12:41 AM
Motoman360's Avatar
It's got to be sims cause it ran fine rite before I hanged the plugs so I no it can't be anything to crazy
Old Aug 25, 2012 | 01:50 AM
Motoman360's Avatar
Simple *
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
