Swap vq's z to g35
Old Nov 19, 2017 | 10:16 AM
raygun's Avatar
Originally Posted by SMG_G35
I have a 05 g35 coupe had a revup motor and the motor blew. So I picked up a motor from an 04 350z motor trans harness and ecu. So I swapped everything in my g and the car won't start. The z motor was running when I pulled it out. There no spark or fuel and I've went back and forth with the ecu's nothing. I've checked all the fuses and everything is connected. Car still won't start. Anybody have any idea?? Lmk thanks!
Ancient thread, but on the off chance that you (or anyone knowledgeable) reads this:
Were you able to resolve this? I’m fighting a similar issue. Alarm light (red one on the dash to the left of the instrument cluster) is on and not flashing with the key in the “ON” position. No power to the OBD port, but the cigarette lighter has power.
With the ECU from the 350Z, no power to the ignition coil harness connectors. With the (original, matches my keys) ECU, power to the coil harness but only 1.3V. Shouldn’t it be around 12? No spark in any case.
All the interior stuff - nav, dash lights, etc. - works. I’d chalk this up to anti theft, but since the OBD port isn’t getting power, scanners and diagnostic tools can’t connect.
Car was sitting for nearly two years. I’m about to go probe the ECU connector to check power and grounds.
If anyone has any suggestions, please speak up!
Old Nov 19, 2017 | 11:25 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If you downgrade from the revup to the non-rev motor you have to rewire the ECU harness because the pin layout isn't the same. Snag both FSM's and compare the harnesses you'll see.
Old Nov 19, 2017 | 12:35 PM
raygun's Avatar
Thanks. I have the FSM for my 06, looking for the one for the 05 350Z. I'm guessing that it should be the same as the 04 G35, hopefully. Looking forward to rewiring a 150-ish pin harness connector. :/
The funny thing is that, even with the computer that came with this engine and harness - JDM from an 05 350Z - , there's no power to the OBD port. I'm tracing through the wiring diagrams, still trying to figure out which fuse is for what in the fuse and relay block behind the battery.
Old Nov 19, 2017 | 01:28 PM
raygun's Avatar
And, now looking at the harnesses in the passenger compartment and connections to the engine harness, I see they're VERY different. This'll be fun.
Old Nov 19, 2017 | 01:58 PM
raygun's Avatar
After a little more research and crawling all over the car: I'm wondering if it makes more sense to swap out the wiring harness on this engine - replace it with the one from the rev-up. I'm building a map of which wires need to be moved, and it's non-trivial, to put it lightly.
But, getting the harness off with the engine in the car might also be non-trivial. Now, where'd my flashlight go...
And, then there's the issue of how the ECU will deal with not being able to talk to the missing VVT components. I found this thread:
https://g35driver.com/forums/g35-cou...non-revup.html
Which indicates that the car will run, but will throw a CEL. I'm okay with that. The other harness would also give me back the variable-assist steering that's missing from the 350Z harness, and I wouldn't have to worry about the antitheft BS and getting keys reprogrammed. There's also no guarantee that there's a 1:1 relationship between the Z harness and the G harness. The smaller of the two white connectors in the passenger foot well has quite a few more lines going to it on the G harness...
Guess I better get started.
I'd love to hear from anyone that's done this before.
Old Jan 4, 2018 | 04:28 PM
raygun's Avatar
In case anyone else winds up trying this:
I wound up using the G35 engine harness, 350Z ECM and (duh) 350Z non-rev motor. I didn’t have to splice the harness at all, though there are four extra connectors I had to protect against the elements. They’re for the rev-up VVT sensors and actuators that aren’t present on the donor engine. I had planned to use the G35 ECM, but I think I fried it at some point. Shrug.
I had to reprogram the ECM due to NATS. I did this with a VAG-K OBD2 cable and Nissan DataScan (NDS) software. (About $50 if I remember correctly, much cheaper than a trip to the dealer!) On your BCM - driver’s side footwell near the dead pedal - there is a 5-digit hex code labeled ‘PIN code’. There are a number of apps available that will convert that code to a 4-digit code that NDS needs to reprogram the car. I found a free web-based tool (http://keytechtools.com/bcmcodes/index.php). If that tool isn’t available, worst case is you pay someone on justAnswer to decode it for you.
The only real issue was that my car has 6-wire wideband downstream O2 sensors, while the donor engine had 4-wire narrow band sensors. I just swapped the wide bands over to the new engine and, oddly enough, the 350Z ECM reads them just fine. I’m a software guy; I’m not surprised the ECM *can* do that, more shocked that it *does* without modifications.
I have a CEL due to the missing VVT components, but I’m not super-worried about it. Car runs fine, no noticeable power difference.
So, to all those that said you can’t replace a rev-up with a non-rev VQ:
Well, you can.
Also: the NDS software is *awesome.* Being able to do things like deactivate individual cylinders (for testing spark and fuel), see the output of basically every sensor on the car, etc. is incredibly helpful when debugging the car. I’d say it’s as good, or better than, HP Tuners (for my other GM car), and about 1/10th the price. It's not as capable as a real Consult II, but it did everything I needed for this swap.
Old Jan 4, 2018 | 04:55 PM
cleric670's Avatar
BANNED!!!
You have proven us wrong!
Glad you were able to get everything running again, I hate to see G's turn to dust.
Old Mar 11, 2018 | 06:17 PM
raygun's Avatar
Fun video, first run:
The oil on the driver’s exhaust manifold burned off pretty quickly.
Old Jun 5, 2018 | 10:27 PM
sherm3721's Avatar
This has been very useful! I am currently in the process of putting an '06 G35 Rev Up into a, '04 350z Non Rev Up. Swapping over the engine, harness, and ECM. I have the pins all mapped on the F1, F2, F3, and F102 connectors of what I need to swap around to get the G to map to the Z (the four connectors that the engine wiring harness connects to the rest of the car with). Well, there are still two wires that I am not sure what they do from the G harness. Maybe they are the two wires you mentioned? Not sure.
Anyway, I don't think I will have the luxury of not rewiring connectors since I am putting the Rev Up into a Non Rev Up DE car.
Raygun, were there any other tidbits of knowledge you have that may be useful for me?
Old Oct 3, 2020 | 04:09 PM
Kyle Benjamin's Avatar
Revup
Year of the ecu?
[QUOTE=raygun;7126682]In case anyone else winds up trying this:
Well, you can.
Also: the NDS software is *awesome.* Being able to do things like deactivate individual cylinders (for testing spark and fuel), see the output of basically every sensor on the car, etc. is incredibly helpful when debugging the car. I’d say it’s as good, or better than, HP Tuners (for my other GM car), and about 1/10th the price. It's not as capable as a real Consult II, but it did everything I needed for this swap.[/QUOTES
What year is the ECM you used?
Old Jun 7, 2024 | 04:58 AM
bigbodyg35's Avatar
Infiniti g35 coupe 6mt
Well, you can.
So, I just bought a 06 revup manual g35 coupe with a blown motor. Currently on the way to Pa from tn. I have a 04 non revup g35 with a very healthy motor but that’s about it, the rest of the car has gone to ****. Anyways plan on attacking a rev up to non rev up swap. Now with that being said it sounds like it’s the easiest side of the swap(putting revup in non revup chassis sounds horrid) gonna try to do exactly what this message I’m quoting says. Now I do have a question of which ecu do I use? The revup one that’s in the chassis I will be driving or the non revup from the donor motor car? I have nds and both keys so wondering if both would work. The revup ecu is tuned non rev up is not. Would a rev up tune be different then non rev up(I think the answer is yes it’d be different) would it be bad to run that tune on a non revup. Sorry it’s 5am and just trying to run this whole swap through my head before actually doing it. Thanks for the read.
Old Jun 7, 2024 | 05:08 AM
bigbodyg35's Avatar
Well, you can.
also just want to make sure, so did you have to splice the ecu harness or no?
Old Jun 7, 2024 | 11:07 AM
seymore4's Avatar
m56
Much easier option, especially since the revup ECU already has an Uprev license on it is to just tune it for the swap... Shoot me a PM I've done it many times
Old Jun 7, 2024 | 11:48 AM
raygun's Avatar
So, the *correct* way to do this with the parts you have available would be to swap the RU heads onto the non-RU engine, assuming the heads aren't damaged, and keep everything else that's in the RU car.
If you don't do that, you're going to have a merry time splicing wiring harnesses, and you'll wind up with a CEL that won't go away.
Another member had good luck using an ECU from an automatic car with the non-RU engine in an RU car.
Although I got mine running, it was a chore. At the end, I had an issue with a misfire that I couldn't solve. I wound up selling the car.
Old Jun 7, 2024 | 11:54 AM
  #30
seymore4's Avatar
m56
We can take care of everything with an Uprev tune. No need to Frankenstein anything
