engine help
engine help
could anyone help me with the engine temperature gauge? so my 04 g35 coupe have been showing a very slight increase in temperature. i am very concern with over heating the engine. i would like to get an aftermarket temperature monitoring device, so i have a more accurate reading of the engine temperature.. what should i get? how does it work? could i get an engine management system where it would help me monitor my engine in more detail? please help..
thank you
thank you
have you diagnose that the gauge is defective? maybe there is a cooling problem with the car. don't replace the gauge just bc it doesn't tell you what you want to see.
I don't replace my fuel gauge bc it's always near empty and not at full where i want it to be..i just fill it up.
Is it 3/4 close to the HOT or just a very minor increase in the temp gauge? I don't think there anything wrong with your temperature gauge. Could be low on coolant or thermostat going bad.
thank you for the input. i will check out the issue more in detail. but i would like to learn more about engine management system and how to play with them. any input on this issue? what can i do with them and what can i manage with with them. i want a live time visual of what going on in that car. please share your knowledge
Freeman186
Sep 6, 2023 10:07 AM
AuAltima3.5
Sep 13, 2015 10:53 AM
