Found Oil In coolant when i replaced radiator
Old Dec 13, 2012 | 04:34 PM
smokinaces05's Avatar
Exclamation Found Oil In coolant when i replaced radiator
So as the title states when i replaced my radiator last week i flushed out the coolant completely to find oil that was mixed with my coolant.
My car is running fine and the thing is im seeing that when i cold start my car there is a little bit of oil leaking on my drive way, its not a major leak but i did notice it, check my oil stick and the oil looks good but every time i start my car a bit of oil leaks. when i drive to work and go out to lunch though i check under the car and there is no oil leaking under the car
When i was changing my radiator as i was under the car i did notice it seems like oil is coming from the area where my oil filter is at, possibly my oil cooler seal?
Old Dec 13, 2012 | 07:14 PM
terrorx7's Avatar
You should take it somewhere and get a compression test done to see if you may have a blown head gasket or something.
Old Dec 18, 2012 | 12:39 PM
Tolboothwilley™'s Avatar
check your oil - are you seeing water in your oil too?
Old Dec 18, 2012 | 12:41 PM
no water in the oil
Old Mar 2, 2013 | 06:01 PM
RedG's Avatar
<--12 More Years
My buddy had the same problem on his VW, the oil filter housing had to be change and the problem went away.
Old Mar 4, 2013 | 10:42 AM
Blue Dream's Avatar
I drove ttrank's car solo
Oil cooler gasket is a common issue on our cars. Mine was replaced at 47K under warranty, but it's an easy DIY.
KevinnnVo
Oct 14, 2024 04:33 PM
Blakearold
Aug 27, 2015 12:37 PM
yassy
Aug 3, 2015 12:24 AM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
