Idler A/C pulley assembling woes...06 G35
Old Jan 10, 2013 | 11:54 AM
phatrabbitzz's Avatar
I replaced my A/C and alternator belts because they were squealing, unfortunately after I replaced them I started hearing some clicking noises only while driving, the noise stops when car is idle.
I removed the idler pulley and pulley alone doesn't make any noise.
However when I put the dust cover and the thick bearing there seems to be some wiggle room for that thick bearing to move, see pic 2. Is that normal? If I move this whole thing assembled back and forth I can hear that rear bearing move between the pulley and the dust cover.
In addition when this goes back on the car there's a bracket between the screw and that rear dust cover, but even without it I barely have space to put the lug nut at the end (see pic 3 and 4). What am I doing wrong? I know there should be more space for that screw since a bracket is supposed to be in there as well.
Old Jan 11, 2013 | 12:25 PM
LoSt180's Avatar
You have it assembled backwards. The flat side of the pulley should face out.
Found a good picture here: http://my350z.com/forum/5104978-post1.html
Old Jan 11, 2013 | 01:17 PM
You're right, I played around with it yesterday and realized I kept trying to assemble the pulley backwards. Thanks!
Old Jan 24, 2013 | 03:42 PM
wallofgrath's Avatar
P.S. smart to use those Nissan belts, I used Dayco and they squeal in the cold no matter how much I adjust them.
Old Jan 24, 2013 | 03:47 PM
Frankieg35's Avatar
Just do the idler pulley delete..
Old Jan 24, 2013 | 05:57 PM
ZGagnon's Avatar
That isn't the pulley your able to delete
i may be replace both remaining idler pulleys, when i removed em, when loosening the nuts they didnt even loosen... just spun.. just cut the belts off
Old Jan 24, 2013 | 10:44 PM
Tolboothwilley™'s Avatar
you did loosen the nut holding the idler pulley in position before twisting the adjustment screw right?
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
teamghost
Jul 28, 2015 04:52 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
