no smoke oil consumption
Old Jan 15, 2013 | 12:10 AM
hawaiian5's Avatar
Ok, this is weird. I swear I just lost 1 qt of oil in just 100 miles. Absolutely no smoke, no leaks , but I do get a strong burning smell. No smoke from engine, exhaust or anywhere haven't had it looked at, but i figure I ask u guys first. I live in Hawaii and the island I'm on has no Infiniti specialists only Nissan dealers. I own a 2003 g35 coupe a/t.
Old Jan 15, 2013 | 06:01 PM
OBsessed's Avatar
If you're using synthetic oil you won't see the blue smoke you're probably thinking of. If you're losing it, there's really only so many places it can go... Have you made sure the drain plug was tight? Any leaks around the valve covers? Install a catch can and see how much is blowing through the PCV valve. Check for pooling around the spark plugs. Get ready to rebuild it.
Old Jan 15, 2013 | 10:49 PM
hawaiian5's Avatar
Ill def have those things looked at. Yes I do use synthetic
Old Jan 15, 2013 | 11:00 PM
gary c's Avatar
Nissan charges 30% less for service than Infiniti
There is no reason you can't have service done at Nissan, there 350Zs are just G35s without our back seat. I get most of my service done at Nissan, the service manager used to work for me. They're always glad to see SLICK roll in, gives they're mechanics something cool to look at....Gary
Old Jan 15, 2013 | 11:31 PM
GFly07's Avatar
Make sure the oil dip stick is all the way in.
Old Jan 17, 2013 | 02:07 AM
hawaiian5's Avatar
Yup oil stick is in. 1 1/2 weeks till they can chk on it. This sucks.
Old Jan 17, 2013 | 02:44 PM
Tolboothwilley™'s Avatar
dont stress it...just check the oil regularly in the morning before you start the car
Old Jan 17, 2013 | 02:55 PM
Texas-G's Avatar
same thing with mine i would just top it off till eventually my motor started knocking...good luck though..just check it every two or three days.
Old Jan 21, 2013 | 02:16 AM
ZnGWindowMotors's Avatar
Check your lower plenum. Oil tends to get sucked in there. The make shift catch can is a good inexpensive fix for that, but it only prevent oil loss, just oil going where it shouldn't
Old Jan 24, 2013 | 03:44 PM
wallofgrath's Avatar
Did you fill the oil filter w/ oil before installing? That's like 1/4 quart of oil right there. I'd tighten the filter, drain bolt, and top it off and only get worried if you continue to lose oil every 100 miles.
Old Jan 27, 2013 | 05:37 AM
JDMswagSerf's Avatar
hopefully it was the oil filter problem as mentioned above^^.
I don't get why some people think it's okay to lose oil, that it's natural. as well as coolant.
it's suppose to always be the same amount.
KruZZe
Feb 27, 2023 05:04 PM
f22raptor
Mar 18, 2016 08:50 AM
R350k5
Lights
Jan 12, 2016 09:22 AM
mbe32
Nov 13, 2015 11:09 PM
